reffing a JDM b16a questions
Old Jan 20, 2006 | 03:46 PM
DasaEJ1's Avatar
Default reffing a JDM b16a questions
I gotta ref my jdm b16a in my EJ1 (95' Civic Coupe) wondering what else would I need to change to get it to pass.
a stock usdm b16 throttlebody...is what I know so far
oh yeah and how would I disable the knock sensor on my p30 ecu?? I need some guidence on that. something about tappin to the manifold with a wire all the way to your ecu...but I have no idea how to do it and where it would be at on the manifold. if anyone can help me out here...and telling me what to do...I still have a free ref from the last time I had a ref ticket on my jdm single cam and failed. I dont want to let this free reffing go to waste. and I got this JDM b16a from a JDM EG6 thats the story.
Old Jan 20, 2006 | 08:32 PM
boysnightout's Avatar
Default Re: reffing a JDM b16a questions (DasaEJ1)
correct me if im wrong, but jdm motors can't pass state ref's.
Old Jan 20, 2006 | 08:43 PM
D16z6BoostedEK's Avatar
u need stock airbox and usdm intake manifold and all sensors!
Old Jan 20, 2006 | 09:21 PM
Hybrid96EK's Avatar
Default Re: reffing a JDM b16a questions (boysnightout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boysnightout &raquo;</TD></TR><TR><TD CLASS="quote">correct me if im wrong, but jdm motors can't pass state ref's. </TD></TR></TABLE>
JDM engines can and will pass the ref just fine. Thats not the issue.
#1, you don't want to disable the knock sensor. Fix the problem the right way. Half assing things will catch up to you in the end. Leave the ECU 100% stock, make sure its a California emissions group ECU also. Put on the stock airbox for sure and then head out.
Old Jan 20, 2006 | 09:48 PM
VtecSyndrome's Avatar
Default Re: reffing a JDM b16a questions (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
#1, you don't want to disable the knock sensor. Fix the problem the right way. Half assing things will catch up to you in the end. Leave the ECU 100% stock, make sure its a California emissions group ECU also. Put on the stock airbox for sure and then head out.</TD></TR></TABLE>
Threads like this make me glad to be in NC, VERY slack and easy to get by out here and 93 octane all day long!
Old Jan 20, 2006 | 10:06 PM
broketuner-Sol_Si's Avatar
Default Re: reffing a JDM b16a questions (VtecSyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDrock86 &raquo;</TD></TR><TR><TD CLASS="quote">u need stock airbox and usdm intake manifold and all sensors!</TD></TR></TABLE>
WRONG. When I had my swap(JDM b16A) inspected(as you can tell by my sig., it passed) I had an injen CAI intake (meant for the original motor a non-vtec sohc). I passed with a complete JDM everything except the ECU.
1st thing though, make sure the engine is the year or newer compared to the car, if this isn't doine your pretty much FUBARed right off the bat.
Here's what I needed:
-O2 sensor(Brand new genuine honda part, not a cheap bosch universal)
-New Cat(I passed with a hi-flow one, I was shocked, better go as restrictive on this as possibleto pass, you can always take it out later.)
-All wiring done to look like OEM (solder and heat shrink)
-MOST IMPORTANTLY a USDM ECU for that engine
Here's some other things I'd reccomend:
Change all the belts(won't help you pass but, it's added insurance for something not breaking)
Oil change (synthetic oil of course)
Tune up (plugs, wires, cap and rotor)
Pray that you pass(I did and it worked for me...lol)
Also, there's a couple of old threads about the ref stations in the FAQ of this forum, read up on it....not all ref stations are the same, some are real strict and everything has to be just so and then others are more relaxed.
Old Jan 20, 2006 | 10:07 PM
2000EM1's Avatar
Default Re: reffing a JDM b16a questions (broketuner-egb16a)
I'm learning a shitload in this thread... mainly of just how shitty you californians have it. Move the expletive outta that state.
Old Jan 20, 2006 | 10:30 PM
b16greenmachine's Avatar
Here's my list of what I did. I have a 96 ek with a b16 in it, in CA, and passed. Your lists look quite short. Keep in mind that my car was also missing a few parts. This is a list I got from the REF. Hope this helps some people out.
p30 ECU US
99-00 CIVIC SI INTAKE MANIFOLD
THROTTLE BODY GASKET
99 CIVIC SI INTAKE BOX
99 CIVIC SI INTAKE ARM AND PIPE
OBD-2 INJECTORS
99 CIVIC SI CAT CONVERTOR
CRANK ANGLE SENSOR
LOWER TIMING BELT COVER
CRANK ANGLE SENSOR SPROCKET
UPPER TIMING BELT COVER
99-00 CIVIC SI CHARCOL CONISTER
INTAKE MANIFOLD GASKET
P.S. -- this is also the "correct" way to do it, as far as I know, but I know there are many shortcuts. so w/e take this info as you want
Old Jan 20, 2006 | 10:35 PM
On another note, what I would do first would be to go to the REF have him smog it and look at it and have him give you a list. If you don't, you might end up getting **** you don't really need. Good Luck
Old Jan 20, 2006 | 10:38 PM
Del Sol SiR's Avatar
you need to match most of the stuff from the 94-95 Honda Del Sol VTEC that came with the B16A3 to stay OBD1
Old Jan 21, 2006 | 10:18 AM
95DxSi-R2
Guest
Posts: n/a
Default Re: (Del Sol SiR)
search!
Old Jan 21, 2006 | 12:03 PM
JDMhatch22a's Avatar
i passed jdm motor, stock p30 and an itake...you dont need anything except a good motor
Old Jan 21, 2006 | 07:36 PM
Default Re: (JDMhatch22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMhatch22a &raquo;</TD></TR><TR><TD CLASS="quote">i passed jdm motor, stock p30 and an itake...you dont need anything except a good motor</TD></TR></TABLE>
depends on where you live dumass, CA has strict emission rules, and that's where DasaEJ1 lives. I don't know about arizona, but I thought that in most states jdm motors had to have USDM parts..?
Old Jan 24, 2006 | 06:16 PM
DasaEJ1's Avatar
Default Re: (b16greenmachine)
thx...wondering has anyone ever passed with a vafc on before?? **** would be sick if I can but I never heard of anyone passing with it on before...
Old Jan 27, 2006 | 07:05 PM
DasaEJ1's Avatar
Default Re: (DasaEJ1)
hey what about my p30 ecu...my knock sensor is going to show check engine light...how do I fix that?
DasaEJ1
Feb 1, 2006 09:34 PM
vtecnologist2
Apr 29, 2004 06:20 PM
everidge4
Jan 25, 2004 01:12 PM
Vtec_Turk
16
Oct 10, 2003 12:27 PM
chefcris420
Jun 14, 2001 01:20 PM
