oem o2 senser or universal?
Old Jan 20, 2006 | 02:00 PM
Baron55's Avatar
Default oem o2 senser or universal?
I want to replace both sensors on the gsr..I went to autozone and oem was like $300+ and others that are universal like 60 something and 150-200.... Should i stay oem or it doesnt matter.....why such a huge difference in price?
Old Jan 20, 2006 | 02:28 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: oem o2 senser or universal? (Baron55)
Just the OEM plug is different. If you buy a universal one, you will need to reuse your OEM plug. It is well worth it for the price difference.
Old Jan 20, 2006 | 02:36 PM
Baron55's Avatar
Default Re: oem o2 senser or universal? (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Just the OEM plug is different. If you buy a universal one, you will need to reuse your OEM plug. It is well worth it for the price difference.</TD></TR></TABLE>
well worth it? how much better or different can the oem be? i dont mind getting oem but if its a waste $$ then i will just get any equivalent/universal
Old Jan 20, 2006 | 03:36 PM
quiksheit's Avatar
get the universal. there'll be instructions on what to do to connect up the universal. easy as just connecting a few wires to the harness off the old O2 sensor
Old Jan 20, 2006 | 08:16 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Baron55 &raquo;</TD></TR><TR><TD CLASS="quote">
well worth it? how much better or different can the oem be? i dont mind getting oem but if its a waste $$ then i will just get any equivalent/universal</TD></TR></TABLE>
You misunderstand. I'll gladly pay $50 for the universal sensor. It will take me 10 minutes to wire it properly. Hell, that's a $1200/hour skill.
Old Jan 21, 2006 | 12:39 AM
LSvtec03's Avatar
you can go to autozone and get one for a little more than the cost of a universal that comes with the plug already wired on.
Old Jan 21, 2006 | 09:03 AM
Baron55's Avatar
so, getting the universal is good, any downsides to it compared to oem?
Old Jan 21, 2006 | 11:01 AM
shorto85's Avatar
Get the NGK O2 sensor... plugs right into the stock harness! And its only $50
Part# 24172
Old Jan 21, 2006 | 11:04 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: (shorto85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shorto85 &raquo;</TD></TR><TR><TD CLASS="quote">Get the NGK O2 sensor... plugs right into the stock harness! And its only $50
Part# 24172 </TD></TR></TABLE>
That is a good price for a plug and play sensor. From where are you buying it?
Old Jan 21, 2006 | 04:26 PM
Baron55's Avatar
Default Re: (Dogginator)
That is a good price for a plug and play sensor. From where are you buying it?</TD></TR></TABLE>
yeah where?
Old Jan 21, 2006 | 07:22 PM
88redrex's Avatar
Don't get the autozone bosch ones...suck suck suck
NGK or Denso is good
Old Jan 21, 2006 | 09:03 PM
LSvtec03's Avatar
Default Re: oem o2 senser or universal? (88redrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88redrex &raquo;</TD></TR><TR><TD CLASS="quote">Don't get the autozone bosch ones...suck suck suck </TD></TR></TABLE>
they're fine.
Old Jan 22, 2006 | 12:50 AM
Baron55's Avatar
NGK or Denso is good</TD></TR></TABLE>
ok, but from where?
Old Jan 23, 2006 | 12:31 PM
quiksheit's Avatar
care to elaborate why the bosch ones suck???
Old Jan 25, 2006 | 02:36 PM
Dogginator's Avatar
Daisy... Daisy...
Its available directly from NGK:
http://www.ngk.com/results_app.asp?aaia=1382802
The rear O2 sensor is still expensive.
Todd00
Apr 3, 2011 07:37 PM
commutercar
Jan 17, 2008 08:04 AM
MugenHonda
Jul 8, 2005 08:15 AM
WangChung
10
Nov 27, 2003 08:38 AM
