Installation of Cold Air
Old Jan 20, 2006 | 09:59 AM
SigmaOmega's Avatar
Default Installation of Cold Air
I know this is one of the easiest mods to do, but i want to make sure im doing it right. Can anyone give me a link to see what a person does to correctly install a cold air (with pics). Thank you.
Old Jan 20, 2006 | 10:14 AM
Luserkid's Avatar
Default Re: Installation of Cold Air (SigmaOmega)
uhh.... you put the pipe on then the filter. You cant really put it on any other way, it only goes on one way.
mluckxxx's Avatar
how do you install cold air?
Old Jan 20, 2006 | 10:17 AM
onegreedy's Avatar
dont forget to fill the filter full of ice to get real cold air
*******************(this is a joke do not really put ice in your filter or you will hydroloc your motor)*****************************
Old Jan 20, 2006 | 10:23 AM
SigmaOmega's Avatar
gee, thanks, no really the pipe i have for my D16Z6 just seems too long (i know which direction it goes). Its a standard two pipe system that was made for a D16Z6 (or at least thats what it says).
Old Jan 20, 2006 | 10:24 AM
dohcVTECeg2's Avatar
Default Re: (onegreedy)
its pretty basic.
Old Jan 20, 2006 | 10:26 AM
SigmaOmega's Avatar
well then there is no point on me even saying anything when ppl say its pretty basic or its fairly simple. Im not getting anywhere, all i want is a link, plain and simple.
Old Jan 20, 2006 | 10:31 AM
JDM Vision's Avatar
hook 1 end up 2 ur TB and stick the other end into the little hole under ur stock air box and go under the car and put the filter on
Old Jan 20, 2006 | 10:42 AM
hunc02's Avatar
http://www.g1teg.org/howto/diy_intake.html
http://www.automedia.com/Cold/...1ai/1
Old Jan 20, 2006 | 11:32 AM
IHateJDM's Avatar
Default Re: Installation of Cold Air (hunc02)
it should be self explanatory. if its not, you were probably given the wrong intake. if that's the case you can try to exchange it with whoever you got it from, or get a hacksaw and make it fit.
Old Jan 20, 2006 | 11:34 AM
Elwuudz's Avatar
move to iceland..... the is a cold air installation up there
mostly navy people but its an airforce base
don't be afraid to tackle projects/bolt-ons like this one
when the tedious tasks like tightening qnd keeping alignment of timing belts and tracing ecu codes come up you will be asking too many questions
best thing to do with something like this.... is jump in
takes 2-10 min with proper tools a screw driver and wrench to tighten bracket
Old Jan 20, 2006 | 11:35 AM
SovXietday's Avatar
Default Re: Installation of Cold Air (IHateJDM)
Yeah, if all else fails just hacksaw it and make it a short ram, that will definitely fit, and they won't hydrolock.
MCHAccordLX
Nov 12, 2006 04:37 AM
piggydog
Oct 13, 2005 01:30 PM
crooked muffler
May 21, 2003 02:57 PM
