Transmission Leak After clutch job 97 LS
Old Jan 20, 2006 | 07:41 AM
I Want An Si's Avatar
Default Transmission Leak After clutch job 97 LS
Did a clutch job and the only thing i can think of is that i overfilled the tranny and its leaking because of it(seems to be coming from near the big plug that takes a 1/2" ratchet to tighten, although i cant be sure)
Anyone else run in to something/anything similar... suggestions...
Old Jan 20, 2006 | 08:03 AM
TRE_'s Avatar
Default Re: Transmission Leak After clutch job 97 LS (I Want An Si)
you cant over-fill the transmission so thats not the problem. check your axle seals
Old Jan 20, 2006 | 09:17 AM
Default Re: Transmission Leak After clutch job 97 LS (TRE_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">you cant over-fill the transmission so thats not the problem. check your axle seals</TD></TR></TABLE>
its not leaking around the axles its leaking more towards the front of the transmission
Old Jan 20, 2006 | 12:23 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I Want An Si &raquo;</TD></TR><TR><TD CLASS="quote">its not leaking around the axles its leaking more towards the front of the transmission</TD></TR></TABLE>
from the fill bolt? then you could ove over-filled it or you need to replace the crush washer.
error
Jun 10, 2007 06:41 AM
R.Kelley
21
Sep 29, 2006 08:20 PM
Ponyboy
Acura NSX
16
Sep 20, 2005 08:03 AM
jondancer
May 10, 2004 04:32 PM
vtekthis
Mar 24, 2004 06:11 PM
