PLZ HELP! Accord stuck in PARK! Need to fix by tonight
Old Jan 20, 2006 | 07:21 AM
armaniazn1's Avatar
Default PLZ HELP! Accord stuck in PARK! Need to fix by tonight
After I turn on the car, I can't take it out of [P]ark. The car starts fine, but the shifter is locked in [P]
<I had to manually unlock the shifter with the key, then put it into [N]eutral, then start up the car then it runs fine>
But later on I see that my brake lamps aren't lighting up. Maybe there's a problem with the fuse or something?
Any help would be GREATLY appreciated since I have a long road trip I have to make TONIGHT !
Thank you and have a nice day!
Old Jan 20, 2006 | 08:29 AM
JimBlake's Avatar
Default Re: PLZ HELP! Accord stuck in PARK! Need to fix by tonight (armaniazn1)
Look down at the brake pedal for the switch that turns on the brake lights. That also tells the interlock solenoid to release the shift lever. Look for bent or broken bracket for that switch, maybe unplugged wiring, or something like that. Or maybe the switch has just gone bad...
Old Jan 20, 2006 | 09:12 AM
accordisslow's Avatar
Default Re: PLZ HELP! Accord stuck in PARK! Need to fix by tonight (JimBlake)
try sticking your key in the slot next to the shifter. mmaybe that will help
Old Jan 20, 2006 | 09:34 AM
HondaAccordTdR's Avatar
parked on a hill?
bdub5226
Aug 15, 2011 08:48 PM
CooBreeze
Apr 10, 2009 11:46 AM
boblikesrock
Nov 29, 2006 06:55 PM
hybrid_KJ
Jan 29, 2006 07:29 PM
dintegra97
Apr 11, 2005 06:28 PM
