91 teg starts then stalls
Old Jan 20, 2006 | 03:52 AM
scheistermeister's Avatar
Default 91 teg starts then stalls
in not getting a CEL, all fuses good, fuel pump good, new sparkplugs, distributor, plugwires and it has gas.
it starts up for like a second then stalls out. im new to the whole honda thing so i was wondering what would you guys check next? i was thinking possible clogged fuel filter or clogged cat. anyone else have any ideas? its all stock. oh and i played with the timing a little. didnt really change anything.
Old Jan 20, 2006 | 11:54 PM
Default Re: 91 teg starts then stalls (scheistermeister)
update: pulled main relay out and tested per FSM, but i have a question on it. i think its good, but not sure. when i hooked it up like the FSM said and checked it with the multimeter it clicked and showed the voltage, but the voltage was only there for a second. is that the way its supposed to work? it did that for each step of the FSM.
nevermind: found the problem, previous owner is a liar and a thief and a retard
Modified by scheistermeister at 3:03 AM 1/21/2006
Modified by scheistermeister at 4:30 AM 1/21/2006
Old Feb 2, 2006 | 03:36 PM
efyou's Avatar
what was the problem?
Old Feb 2, 2006 | 06:09 PM
rotor in the distributor was RTVed into place, the gear in the distributor was all sorts of FUBAR and the timing belt had jumped about 3 teeth.
runs great now that i fixed it tho
mcalvelloxx
Jan 27, 2012 05:12 AM
Lude #1
11
Jan 9, 2011 01:05 PM
djw19842005
Aug 10, 2010 12:03 PM
hoggy
May 20, 2007 11:33 PM
trimagna
Jun 10, 2005 09:12 PM
