would type-s pistons be worth it...
Old Mar 21, 2002 | 09:12 PM
4bidden's Avatar
Default would type-s pistons be worth it...
I'm about to do my H22 swap into my 92 Si and was wondering if the Type-S pistons would be worth purchasing. I've found them for $380 w/ rings. Later I plan on putting in some Skunk2 stage II cams and their springs/retainers and was just planning ahead because I know higher compression will make a bigger difference with some cams that breathe better. So do you think an extra $380 now would be worth it? And if you have any place you know that sells them cheaper than $380 new than let me know also. Thanks!
Old Mar 21, 2002 | 09:54 PM
Quaalude's Avatar
Default Re: would type-s pistons be worth it... (4bidden)
if u are going allmotor then i would get them...i think http://www.jdmhondaparts.com has them for cheaper...if u use these pistons, u won't need to sleeve your block...forged pistons u will most likely have to sleeve it
Old Mar 21, 2002 | 09:57 PM
4bidden's Avatar
Default Re: would type-s pistons be worth it... (Quaalude)
a jdm h22 is 10.6:1, is .4 going to make a $400 difference though? or would i be better off saving that $400 and adding a vafc when i do my cams and stuff or maybe even use that $400 and apply that to a p&p job when i do my cams. choices choices
Old Mar 21, 2002 | 09:59 PM
Quaalude's Avatar
ohh...i thought u were talking about the USDM H22A...no i wouldn't buy them...just save the money for a VAFC or cam gears...if u are getting skunk2, then i would definitely get the cam gears
Old Mar 21, 2002 | 10:08 PM
4bidden's Avatar
yea...when i said im getting skunk2 cams....springs/retainers/cam gears/ fpr....all that is together. so yea...the $400 wouldnt apply to cam gears but good call
Old Mar 22, 2002 | 03:53 AM
import-store's Avatar
i sell h22 type s piston/rod for 250.99 if your interested.
Old Mar 22, 2002 | 05:25 AM
WICKED2's Avatar
New User
Default Re: would type-s pistons be worth it... (import-store)
i'll take da type-s piston if u'r willing to wait for 2weeks.....cuz dat's when my edd comes in
hehehehe
Old Mar 22, 2002 | 06:41 AM
laughinxxx's Avatar
New User
Default Re: would type-s pistons be worth it... (WICKEDII)
hehehehe
English please.
Old Mar 22, 2002 | 06:50 AM
a1andres's Avatar
New User
Type-S pistons will give you 11:1 CR
Old Mar 23, 2002 | 10:28 PM
Razor's Avatar
Default Re: would type-s pistons be worth it... (a1andres)
is it only the pistons that give the real type s motor 11:1 compression or is it also the different head gasket ?
OD4g
Nov 16, 2006 09:48 AM
darockstar
Jan 19, 2006 03:26 PM
SixguN
36
Apr 22, 2005 11:42 AM
ALL MOTOR EF8
28
Jan 10, 2005 05:42 PM
