ek steering/handling problem
Old Jan 19, 2006 | 08:12 PM
20civic00's Avatar
Default ek steering/handling problem
hey guys, when i slammed my 2000 civic coupe, I of course had to get the camber/toe done. So I got skunk2 ajd. in the front, and that took care of the front, and for the rear, I had to get upper ajd, and also lower control arms that we're a lil shorter than OE to suck the bottom of the tire in, so the top could be adjusted properly. I'm sure you've seen them, Omni has them,Cusco,etc. I put them all on, and had Les Schwab to the alignment. Here's the problem...even though the car has proper camber and toe, it is handling really strange. Lets say Im on the freeway, and I make a quick change over to the next lane...the rear of the car feels like its "following" me...its kinda hard to explain, but the rear feels like it does an "after waving effect", almost like the rear is playing catch up to my steering. I was wondering if it was because the rear tires are inwards more then the front, because of the extreme rear camber kit I had to put in? I would put wheel spacers in, but I only have a 1/4in or so of clearance from the top of the tire, to my inner rear fender. Sorry for such a long write up, but this problem is really buggin me. Any info helps. thanks HT
Old Jan 19, 2006 | 08:43 PM
97spooncivic's Avatar
Default Re: ek steering/handling problem (20civic00)
do you have a rear swaybar, jw?
Old Jan 19, 2006 | 10:10 PM
20civic00's Avatar
Default Re: ek steering/handling problem (97spooncivic)
just a skunk2 rear lower tie bar, but no upper sway...speaker box is in the way...have to build a custom box to fit one... [IMG][/IMG]
Old Jan 19, 2006 | 10:20 PM
i had this same problem, but it was only when i sway back and forth pretty hard, not just changing lanes. i got a c pillar bar, mostly for looks and not expecting it to do anyting but it actually minimized this "following" thing, i was pretty stocked that a 30 dollar bar did something.
my setup was tokicos, sunk 2 coilovers, suspesnion technique sway bars, and front strut
Old Jan 20, 2006 | 08:53 AM
20civic00's Avatar
yea, it's even worse when I sway back and forth more agressively.It feels like the rear end is goin to get sideways on me!! I'll tray a rear sway bar,and see how much that helps, but i want to fix the problem, not just "reduce it". I don't have the best suspension set up...Gsr shocks and nuerospeed springs, a buddy of mine gave em to me for temperary use untill I get my D2's I also have a front lower H-brace and front strut.
Old Jan 20, 2006 | 12:04 PM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
the camber on my 97 coupe is worse in the back than the front. my cars slammed
Old Jan 20, 2006 | 12:29 PM
20civic00's Avatar
Default Re: ek steering/handling problem (honduhh)
did u put any kind of camber kit in the rear?
Old Jan 20, 2006 | 12:33 PM
egsleepercivic's Avatar
to the poster, sway bars and strut bars are different a speaker box will never get in the way of a sway bar
Old Jan 20, 2006 | 01:34 PM
_HANS's Avatar
Default Re: (egsleepercivic)
speaker box is inside the car!!
Old Jan 20, 2006 | 02:41 PM
20civic00's Avatar
Default Re: (honduhh)
lol, right! good catch but at least u guys new what I was talking about!! this still isn't helping my problem though!! C'mon, isn't there anyone out there with some know how on this kind of thing?!
Old Jan 20, 2006 | 02:42 PM
20civic00's Avatar
jeeze, i hate bein a noob
Old Jan 20, 2006 | 03:08 PM
b18ccivics's Avatar
Default Re: (20civic00)
a sway bar in the rear will not help, they are to keep the body level when turning and helping the car to rotate. it sounds like the rear toe i out, i put a set of rear spc lower arms on like you described and upper camber kit (all for the rear) and i didnt have enough adjustment for toe (the toe adjuster is bottomed out towards the center of the car) so i bought a set of suspension technequies (i cant spell) rear toe adjuster and fixed the problem now handles like a champ.
Old Jan 21, 2006 | 02:38 PM
20civic00's Avatar
Default Re: (b18ccivics)
thanks! I'll give it a try, where did u pick yours up at and how much?
Old Jan 22, 2006 | 09:27 AM
b18ccivics's Avatar
and spc makes them too
Brewbot87
Suspension & Brakes
Jun 3, 2014 05:15 PM
GrenadaEG2
Suspension & Brakes
Nov 27, 2009 10:25 AM
StolenTeg
Jul 2, 2006 11:26 PM
klomast3r
Sep 6, 2005 08:40 AM
RED EK NJ
Suspension & Brakes
Mar 27, 2005 12:58 PM
