jdm headlights and side markers???
JDM Headlights-
Do they make a HID kit for the H4H bulbs that are found in the jdm headlights? If so, to get them do I have to special order them from Japan??
Sidemarkers-
I know it uses the wedge bulb (194) and it can be hooked up either with the parkin light or blinker, Does anyone have them hooked up with a relay of some sort to function as both. IE: With the parking lights off it will light up to blink and with the parkin lights on it with stay constant on but will also blink (on, off, on, off, etc..). If anyone has this do you have a write up or what kinda relay did you use. if not then i'll do some research and do a write up for it.
Peace n Thanks!!
Sidemarkers-
Peace n Thanks!!
huh?? im lost? what do u mean by that? the side marker jus have for two wires so wont it cause a short or fry a harness if i cross the parkin light n turn signal wire together?? Thanks tho!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frosty R81 »</TD></TR><TR><TD CLASS="quote">try it like this
sidemarker > corner light wires
black > red
red > green
that way, it should act as both</TD></TR></TABLE>make a picture instead
black > red
red > green
i also heard that one of the markets had sidemarkers with dual filament bulbs so they wired to both the blinker and parking light...
no it wouldnt short it out and im positive, cause i did to my car yesterday.
sidemarker has 2 wire
most likely red1 and black1
corner light has three
red2, green, black2
if you want it to only blink with the signal, wire red1 to green and black1 to black2.
if you want it to be on with yo city lights, red1 to red2 and green to black1. this way, when you turn the handle thing once, the sidemarker will be on. and when you signal it will alternate with the corners.
red2, green, black2
I just wired my markers to the turn signal the 5 days ago
green................................. + turn signals
red......................................+ low/high beams
black................................... - ground
JDMland, ebay and 50 other websites offer up HID adaptors fot the h4h/H4 plugs
Ranging from 150$-2500$
jdmland and passwordjdm offer up h4 balasts for the fogs in EG's and the crx del sol
They also offer up affordable HID kits with decent lumens for the $$
The assembly will plug right up to ur stock plug and draw the same 35/45watts; while offering a light output that of a 110-120w halogen
These HID kits have small modules that can bolt to the chasis or be easily hidden ne where. These kits are a feasable upgrade for anyone seeking superior lighting.
Keep in mind the H4h HID kits can be used inconjunction with any light that has an H4 balast.... seach HT yesterday for a DIY version of a H4 balast conversion for HID
t0ekn3e
Apr 8, 2004 11:41 PM
Suprdave
Jan 13, 2002 04:56 AM
