b16a 90 crx si clutch cable issue
Hey, I recently recieved my b16a from Hmotorsonline to put in my 90 crx si and the bracket that goes above the clutch cable lever thing on the transmission is not there. Its the bracket where the little adjuster thing on the clutch cable goes. My question is, where would be the easiest place to find that part? Any help would be appreciated.
You should contact where you purchased the swap from and they should send it to you.
Local dealer, but most of the time, they have to order it so that is 2-3 days.
A complete engine swap should have that bracket -ours do -so contact where you got it from, sure they will send you one.
ADAMnQuickRDX
Mar 22, 2009 11:39 AM
