motor shut off after disconect bettery cable?
Old Jan 19, 2006 | 06:32 PM
ef nine's Avatar
Default motor shut off after disconect bettery cable?
my friend did the swap for me today. first time he start the motor it start up fine. but when he disconect the nagative cabel motor just off by itself???????? what wrong with it maybe he wrie somthing wrong??
Old Jan 19, 2006 | 06:38 PM
Mach69's Avatar
Default Re: motor shut off after disconect bettery cable? (ef nine)
You are telling me that when your friend disconnected the negative terminal of the battery the engine dies? Isn't that what is suppose to happen by any chance?
It could be an open wire, or more likely you have an alternator problem.
<U>Someone confirm. </U>
Old Jan 19, 2006 | 06:44 PM
ef nine's Avatar
yes when he took out the negative terminal then the engine just die out! but when i had the old motor it never does that. it should be running even you took those terminal off.
but thank for your help i ll check on the alternator anyway.
Old Jan 19, 2006 | 06:48 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: motor shut off after disconect bettery cable? (Mach69)
Not a recommended thing to do..That can cause other problems..
But,As long as everything in the car was turned off,fan,lights/radio amps etc..
it should have kept on running..
Old Jan 19, 2006 | 06:54 PM
digitally_remastered's Avatar
when u disconnect your negative terminal from your battery, the current being created from the alternator will keep your car running even though a ground is not present from the battery. if the car instantly dies when you disconnect the - battery cable then your alternator is bad. its good enough to barely recharge your battery to start the next time or do you have to jump start it. also check your grounds to the engine and also both battery terminals and their mounting areas. if that is not the problem, then your car has some issues.
Old Jan 19, 2006 | 07:26 PM
ef nine's Avatar
thanks for all your help guys
Mikes95eg
Apr 21, 2013 07:26 PM
BigIslandBoi
Aug 22, 2006 09:50 PM
hatch92_88crx
Feb 15, 2006 08:22 PM
hatch92_88crx
Feb 15, 2006 06:59 PM
SOHCmaster
10
May 29, 2005 10:54 PM
