about how much to get a bent valve guide fixed at machine shop???
Old Jan 19, 2006 | 06:07 PM
hatchedeg's Avatar
Default about how much to get a bent valve guide fixed at machine shop???
have a bent valve guide... wondered if anyone has had one fixed at a machine shop/how much??
Old Jan 19, 2006 | 06:12 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: about how much to get a bent valve guide fixed at machine shop??? (hatchedeg)
you don't fix a bent valve...you replace it. 10-20 bucks per valve..depends on what they charge
Old Jan 20, 2006 | 03:26 PM
hatchedeg's Avatar
Default Re: about how much to get a bent valve guide fixed at machine shop??? (Evs-One)
its the valve guide thats bent. not the valve
Old Jan 26, 2006 | 12:33 AM
rotten's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchedeg &raquo;</TD></TR><TR><TD CLASS="quote">its the valve guide thats bent. not the valve</TD></TR></TABLE>
Are you sure about that? They don't typically bend.
I would as a machine shop. Its a bit tricky if I recall, and it is very, very uncommon. I'll sell you one if you'd like (for a B16A). Bought one because I had a valve that wasn't sealing, thought it might be the guide. Turns out it wasn't.
Old Jan 26, 2006 | 03:11 AM
Syndacate's Avatar
Only one? Weird... Usually it's when the timing belt is ligned up wrong that causes valves to bend and when it does it *** rapes the whole upper portion of the engine (all the valves)
raverx3m
May 18, 2011 11:24 PM
KoRE
Apr 13, 2010 09:40 PM
raiden571
Nov 9, 2005 04:45 PM
sinc747
Sep 25, 2005 06:27 PM
