quick question....
Old Jan 19, 2006 | 04:00 PM
:mR. PotAtO heaD:'s Avatar
Default quick question....
i am doing a dohc zc swap in my crx hf.. and i was wondering if the hf bolt pattern would match up? i kno u have 2 bore out the holes in order 4 it 2 fit properly.. but can i use the 1 i have or do i need 2 buy an Si manifold? thank u guys...
Old Jan 19, 2006 | 04:08 PM
ludesrv's Avatar
What manifold??? Intake, Exhaust? You left that a little open.
The exhaust manifold will bolt up I beleive, not the intake, the intake manifold is wider. Even then, the exhaust MIGHT not work, not 100% sure, I never really checked the DOHC ZC.
Old Jan 19, 2006 | 04:32 PM
Default Re: (ludesrv)
o oops... haha i mean the exhaust mani
Old Jan 20, 2006 | 02:23 PM
Default Re: quick question.... (Lilstreetracer88)
another question... i got a pr5 ecu with my swap... which 1 is better? that 1 or a pg7?
Old Jan 20, 2006 | 04:13 PM
crxnj's Avatar
Both ecus are the incorrect ones..THe pr5 ecu is for sohc zc motor and will run the motor lean..and the pg7 is from the 88-89 integra and will run it rich..The pg7 is better though as it is for a dohc motor
The hf exhaust manifold will work fine on the dohc zc..There's so many people using the hf on there motor with homemadeturbo kits..Just have to port it allitle as you know already
Old Jan 20, 2006 | 05:38 PM
Default Re: quick question.... (Mr.speaker)
alright man thanks... i looked on some honda thing and it said the pr5 was 4 the d16a6 and the pg7 is 4 the d16a7 i believe... i think i got 1 wrong or vice versa
Old Jan 20, 2006 | 08:00 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lilstreetracer88 &raquo;</TD></TR><TR><TD CLASS="quote">alright man thanks... i looked on some honda thing and it said the pr5 was 4 the d16a6 and the pg7 is 4 the d16a7 i believe... i think i got 1 wrong or vice versa</TD></TR></TABLE>
No boss,the pr5 is from the integra zxi with sohc zc engines..pg7 is from the 88-89 integra with d16a1 engines..
Old Jan 20, 2006 | 08:10 PM
so what would be the best ecu 2 use?
Old Jan 20, 2006 | 08:12 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lilstreetracer88 &raquo;</TD></TR><TR><TD CLASS="quote">so what would be the best ecu 2 use?</TD></TR></TABLE>
Out of those 2 the pg7 would be better..Like I said its going to run just alittle rich and the rev limit is set alittle higher then the stock dohc zc ecu but it will work better then the sohc pr5 ecu.
Old Jan 20, 2006 | 08:26 PM
alright thanks man
hondacrx_3
Jun 21, 2005 06:42 PM
hondacivic4g
May 12, 2005 10:56 PM
Mr.Death
Jun 11, 2004 09:01 AM
dan89crxsi
Dec 8, 2003 04:48 PM
fkncivic
Oct 1, 2002 12:54 PM
