how much $$ to go crvtec or lsvtec
say i spend between 5-6grand. how much power will i be making then? i'm planning on doing an h22 swap, but if i can get more out of an ls or crvtec for the same amount of money, i'll go that direction. thanks in advance.
I personally think you will get much more out of the b20/vtec than the h22. What will this setup be running in? if its a hatch I seen them put down only mid 14's and b20/vtec I've seen put down like high 12's!!!!
i found a place that sells ls/vtec and crvtec for onlt 1399 here it is http://infinitemotorsports.net/LSVTE...VTEC%20.0.html
That would be correct you can find a b20 block anywhere for $900 and a b16 head for like 300-350 and thats $1,200.. so i would guess that is right
um... I would say that you look around and piece it together yourself much cheaper and better I am getting a 99 si head and a b18b (that im having sleeved and honed to 86mm) all this and a chipped p28 $1150 so look around and you will find a better deal im guessing. Good luck
