Steam / Oil coming out of bottom left valve cover bolt area ASAP help :)
Old Jan 19, 2006 | 03:20 PM
SavEM1's Avatar
Default Steam / Oil coming out of bottom left valve cover bolt area PICS UP NOW
I have a b18c1 that recently had a new crank put in. There is also a JRSC on the engine. My question is that I was at a light and my car died because there (obviously) was not enough oil in my engine. Looking under the hood there was oil everywhere. I put more oil in my engine and let the car idle. Watching it I notice that there is a steam or something like that shooting up from the bottom left valve cover bolt area.
Any ideas? It also may be the vtec sylnoid too im thinking...
Need help ASAP
Modified by Hcivic02 at 12:55 AM 1/23/2006
Old Jan 19, 2006 | 04:03 PM
SavEM1's Avatar
bump
Old Jan 19, 2006 | 05:13 PM
zeroice's Avatar
Default Re: (Hcivic02)
take a pic
Old Jan 19, 2006 | 05:36 PM
SavEM1's Avatar
Well now it doesn't run at all right now. Could it be that my oil pump is not working + other things?
Old Jan 19, 2006 | 05:44 PM
romoracing's Avatar
Default Re: (zeroice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeroice &raquo;</TD></TR><TR><TD CLASS="quote">take a pic</TD></TR></TABLE>
Please do take a pic. I think its your valve cover gasket or cam seal. It even can be a bad/striped head bolt
Old Jan 20, 2006 | 12:29 PM
SavEM1's Avatar
bump...ill take pics as soon as i can get a camera
Old Jan 22, 2006 | 03:55 PM
SavEM1's Avatar
Pics are up
Old Jan 22, 2006 | 04:44 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: Steam / Oil coming out of bottom left valve cover bolt area PICS UP NOW (Hcivic02)
you have a supercharged GSR engine in your civic that was just recently worked on, correct?
yeah its possible someone didnt torque a bolt correctly. Was the head taken off for new studs, and someone didnt hondabond correctly?
Old Jan 22, 2006 | 06:32 PM
SavEM1's Avatar
Im thinking that may be the problem
Old Jan 22, 2006 | 06:34 PM
FuNkDrSpOt's Avatar
Default Re: Steam / Oil coming out of bottom left valve cover bolt area PICS UP NOW (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">you have a supercharged GSR engine in your civic that was just recently worked on, correct?
yeah its possible someone didnt torque a bolt correctly. Was the head taken off for new studs, and someone didnt hondabond correctly?</TD></TR></TABLE>
x2. Buy a new valve cover gasket, buy some hondabond and buy a new vtec solenoid gasket. Hopefully that's all you'll need.
Old Jan 24, 2006 | 12:51 PM
SavEM1's Avatar
ok so i replaced the valve cover and solenoid gaskets and still the same. Car ran for about 5-10 seconds and then just slowly died. Car will not turn on at all now. While it was on steam/smoke was coming up. I opened the oil cap and steam/smoke was coming out of the engine (i say this because car only ran for max 25 seconds)
Old Jan 24, 2006 | 02:33 PM
SavEM1's Avatar
also no coolant in the block.
Car turns over and sounds like its trying to start but nothing. Oil light is on.
Oil pump?
Old Jan 25, 2006 | 01:16 AM
SavEM1's Avatar
Old Jan 25, 2006 | 08:16 AM
littleblue's Avatar
From: On a island w/ only a bridge to leave it, U.S.A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hcivic02 &raquo;</TD></TR><TR><TD CLASS="quote">also no coolant in the block.
Oil pump?</TD></TR></TABLE>
No coolant in the block? Is there coolant at all? That could be what is causing the steam, broken gasget?..Maybe...What does it smell like?
It looks like the there is a bad seal between the distributer and the block...cause thats from what i see the location of the oil..
Old Jan 25, 2006 | 09:33 AM
SavEM1's Avatar
Well i meant no coolant in the block as in there isn't a bad headgasket. Ill check the dizzy seal today
Old Jan 26, 2006 | 11:05 AM
SavEM1's Avatar
so valve cover, vtec solenoid, head gasket, all good so far. Any other ides?
I'm still thinking its the oil pump, anyway I can tell if it is the oil pump?
Old Jan 26, 2006 | 11:21 AM
SOHCD16y8's Avatar
I think you should be as worried about a lil steam coming from your car when it died from having no oil. Why did you have your crank replaced? In doesnt start now? Sounds to me that when you lost all your oil, you spun you bearings, overheated the motor, blew your HG which explains the steam and lack of coolant and ruined your motor which is why it wont stay running.
Old Jan 26, 2006 | 12:28 PM
SavEM1's Avatar
Well at first I thought I didn't have any oil but after I put some in my car I noticed I had too MUCH, which would lead me to the oil pump not work.
edit: and there is coolant, when I said no coolant I mean inside the block (looked through the spark plug holes to see if HG blew)
Old Jan 26, 2006 | 12:51 PM
SOHCD16y8's Avatar
well that pretty much changes everything, as to why it wont run IDK need more info and the leaks need to be described a lil better.
Old Jan 26, 2006 | 07:34 PM
SFWD 1934's Avatar
Default Re: (SOHCD16y8)
Looks like cam seal.
Jason
Old Jan 26, 2006 | 08:53 PM
RTI's Avatar
RTI
So you have no coolant in the block, the oil light is on, the car steams from the valve cover, and you still ran it for 25 seconds? Hope you didn't do any further damage.
As for your car not starting, I would say bad head gasket. Did you check compression? If you noticed your oil was too high are you sure it isn't filled with coolant? How can you be positive your head gasket is fine by just looking down the spark plug holes?
Old Jan 26, 2006 | 09:17 PM
hott95ej2's Avatar
Default Re: (RTI)
sounds like a pcv problem to me, excessive pressure builing in the crankcase dude to compression, but sounds like you need a new motor now
Old Jan 26, 2006 | 09:28 PM
SavEM1's Avatar
Default Re: (RTI)
Well I guess I get people confused when I say there is no coolant in the block...when I say that I mean coolant where there isnt supposed to be...such as right next to the spark plugs. There is a normal amount of coolant in the car, my car did not over heat. While my car was running for those 25 seconds the oil light was not on, it is on afterwards although.
Old Jan 26, 2006 | 09:30 PM
hott95ej2's Avatar
well the oil light stays on when the car isnt running, goes off once the engine is running
Old Jan 26, 2006 | 09:57 PM
SavEM1's Avatar
Default Re: (hott95ej2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hott95ej2 &raquo;</TD></TR><TR><TD CLASS="quote">well the oil light stays on when the car isnt running, goes off once the engine is running</TD></TR></TABLE>
well that I did not know because I never ran in to a problem like this haha *slaps forehead*
TeeGray
Sep 9, 2005 09:57 PM
neocrynym
Apr 12, 2005 08:49 PM
miksew
Dec 26, 2003 09:42 AM
d_mina
Sep 29, 2003 01:05 AM
