short turn radius
Old Jan 19, 2006 | 01:36 PM
zman's Avatar
Default short turn radius
Sorry for the newb question but where exactly is the short turn radius?
Thanks in advance
Old Jan 20, 2006 | 05:03 PM
h22 civic's Avatar
Default Re: short turn radius (zman)
im asuming you are looking to have some head work done and the porter told ya that he would elongate the ports rather then the factory short radius ports,the only thing he is saying is that he will port the head wich inturn will open up the ports making them long radius wich will help air flow better thru your chambers
short radius=air flow turbulence
long radius = smoother air flow
Old Jan 20, 2006 | 06:19 PM
NJIN BUILDR's Avatar
The short turn radius is the turn from the floor of the port to the valve seat insert .Usually including part of the seat insert.
Glenn
Old Jan 20, 2006 | 07:24 PM
mmuller's Avatar
Mad Scientist
Default Re: short turn radius (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The short turn radius is the turn from the floor of the port to the valve seat insert .Usually including part of the seat insert.
Glenn</TD></TR></TABLE>
Old Jan 20, 2006 | 10:20 PM
HiProfile's Avatar
Default Re: short turn radius (mmuller)
From what I've all seen and heard (mainly from people entrusted with porting high-hp/expensive heads) is that you want to raise the roof and not touch the floor. Meaning, you want to make that J shape to an L shape - dig out the top and burrow in towards/arround the valve guide.
Most honda heads flow very well anyways, so you want to increase tumble rather than flow - unless its a 9k+ rpm head. Long turn = flow, short turn = tumble. Check other threads to verify, but I do remember most of that searching I did a while back on this.
Old Jan 21, 2006 | 12:00 AM
zman's Avatar
Default Re: short turn radius (HiProfile)
so its this area?
Old Jan 21, 2006 | 04:20 AM
Yes,thats it.
Glenn
Old Jan 21, 2006 | 05:31 AM
mmuller's Avatar
Mad Scientist
got it right on the 2nd picture
Old Jan 21, 2006 | 07:36 AM
zman's Avatar
thank you sir's.
I am sure i will have lots of questions here soon.
Blair
17
Sep 8, 2021 10:56 AM
Swansen
Jan 27, 2009 11:27 AM
AzCivic1.6
Apr 16, 2006 07:04 PM
ccjustin
Apr 12, 2006 09:35 PM
r46773
Honda Motorcycles
Jul 29, 2003 05:41 PM
