backwards shifting, please help
Old Jan 19, 2006 | 01:11 PM
rumdig2001's Avatar
Default backwards shifting, please help
I don't know what the hell is the matter w/ my 93 lude. From first to second the tranny shifts hard which I found out was common with many of this model, but the problem is fourth gear. My handbook says it is a five spd auto but fourth gear never lasts very long,. Also when cruisin at about 60-70, the car will be in fourth but under load such as climbing a hill I will depress accelerator slightly and it will shift into 5th. Why would it do this, I have readjusted the shift linkage to the tranny many times never exceeding the 3mm limit of travel. I hope one of you have an answer.
Old Jan 19, 2006 | 01:36 PM
Yield's Avatar
Well, for starters, your prelude doesn't have a 5 speed auto so there's a problem right there. 4 gears forward, one reverse.
Old Jan 19, 2006 | 04:56 PM
The_Sober's Avatar
Default Re: (Yield)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rumdig2001 &raquo;</TD></TR><TR><TD CLASS="quote"> I will depress accelerator slightly and it will shift into 5th.</TD></TR></TABLE>
howdja manage that?
Old Jan 20, 2006 | 04:22 AM
rumdig2001's Avatar
Default Re: (The_Sober)
well the book happens to have a typo, anyway the damn thing actually feels like it is shifting and the tachometer shows my frustrations, why the hell is the revs dropping when I give it gas and go up when I let off.
Old Jan 20, 2006 | 06:35 AM
mwprs37's Avatar
Default Re: (rumdig2001)
I have a remedy....5 speed MANUAL conversion...that should do it...
Old Jan 20, 2006 | 09:02 AM
rumdig2001's Avatar
Default Re: (mwprs37)
thanx, that should do it!
Old Jan 20, 2006 | 09:05 AM
iCe_2x's Avatar
I'm taking my auto tranny out soon, if u need a new one I'll sell you mine dirt cheap.
Old Jan 24, 2006 | 04:33 AM
rumdig2001's Avatar
Default Re: (iCe_2x)
no but really, none of you all have any freakin idea as to what causes the car to drop and increase rev's by about 400 rpm under different load conditions. This problem is really annoying and I wish I could fix it asap.
Old Jan 24, 2006 | 07:47 AM
The_Sober's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rumdig2001 &raquo;</TD></TR><TR><TD CLASS="quote">what causes the car to drop and increase rev's by about 400 rpm under different load conditions.</TD></TR></TABLE>
it's downshifting, plain and simple. When your rpms go up, you're in a lower gear.
Old Jan 24, 2006 | 10:30 AM
Finest's Avatar
When's the last time you changed the transmission fluids?
Old Jan 24, 2006 | 10:45 AM
Buffalo's Avatar
Default Re: (Finest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Finest &raquo;</TD></TR><TR><TD CLASS="quote">When's the last time you changed the transmission fluids?</TD></TR></TABLE>
x2
Mmmeecho
10
Jul 28, 2008 09:06 PM
whitelightning
Aug 7, 2005 05:55 PM
kidaniel
Apr 13, 2005 12:12 PM
951dc5
Jan 22, 2005 05:38 PM
shauntfulton
19
Nov 11, 2004 07:35 AM
