prevention question
Old Jan 19, 2006 | 10:45 AM
colombian_accord's Avatar
Default prevention question
Wus up,my car ( accord 4 cyl 2001 ex coupe)just passed the 60k(arat) miles jejeje and I wanted to know what things i have to replace or check after all those miles, thanks ppl
Old Jan 19, 2006 | 10:59 AM
hondadude's Avatar
Default Re: prevention question (colombian_accord)
the owners manual should have the service schedule for you; even though you have extended warranty on the trans, a fluid change is a good idea. A new set of spark plugs and air filter; cabin air filter repacement; check the brakes all the way around.
Old Jan 19, 2006 | 11:28 AM
specbb6's Avatar
Engine oil
Oil filter
Flush coolant (if you didnt do it @ 45k)
Replace air cleaner element
Check BELTS (timing belt, balancer belt)
Check Water Pump
Inspect and adjust drive belts
Inspect front and rear brakes
Replace brake fluid (if you didnt do it @ 45k)
Hope it helps
7mile
Sep 17, 2009 03:45 AM
campos_jeremy
Oct 10, 2008 02:58 PM
KrazyDawg
Mar 18, 2008 04:39 PM
RNPoo7
Aug 21, 2005 02:05 PM
SLoWEk
Apr 13, 2004 07:10 PM
