yes or no... simple question
Old Jan 19, 2006 | 10:36 AM
unrefined7's Avatar
Default yes or no... simple question
I purchased the “red” silicone gasket maker from AutoZone a couple days ago for my transmission oil bolt… just a question, will this stuff work with an exhaust manifold as a gasket? It’s rated at 600F I think or was it Celsius. Not sure but can I use this instead of a gasket? this is an oem header/manifold by the way.
Old Jan 19, 2006 | 10:39 AM
x93coupex's Avatar
Default Re: yes or no... simple question (unrefined7)
to be honest with you it wont last that long
Old Jan 19, 2006 | 10:43 AM
zeroice's Avatar
Default Re: yes or no... simple question (x93coupex)
very well said it will last but i would only give it a month or two
Old Jan 19, 2006 | 10:58 AM
unrefined7's Avatar
can i reuse my old manifold gaskets?
Old Jan 19, 2006 | 11:13 AM
Padawan's Avatar
Darth ModerVader
Default Re: (unrefined7)
Assuming they're in good shape, you can reuse the one at the head and the one between the upper and lower half of the manifold, but I wouldn't recommend reusing the donut gasket at the collector.
Old Jan 19, 2006 | 12:01 PM
Civichatch2k's Avatar
Better off just using the right exhaust gasket. It will save you trouble in the long run.
Old Jan 19, 2006 | 12:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unrefined7 &raquo;</TD></TR><TR><TD CLASS="quote">can i reuse my old manifold gaskets?</TD></TR></TABLE>
If they are in good shape sure. I have done it before without problems and mine were in pretty good shape.
I have since then replaced it when I rebuilt the motor but the gaskets came with some stuff that I ordered. If you have to reuse as long as it is in good shape I would not worry about it.
Rick1t
Feb 9, 2015 05:44 PM
TUR3Ovtec
Jun 14, 2010 03:44 PM
Paluce
May 26, 2005 09:58 AM
Elvis1977
Feb 19, 2004 07:54 PM
Loveless
Mar 13, 2003 12:17 AM
