Oil pan won't come off?
Old Jan 19, 2006 | 06:32 AM
ekim952522000's Avatar
Default Oil pan won't come off?
Ok guys I took off the bottom of the header, i took off the flywheel cover, then i took out all the bolts to the oilpan and I could not get it off I gave it a couple of good tugs tryed to pry it with a screwdriver a bit then gave up because it was raining on me. so i'm lost any ideas?
when i took the one off my prelude it just fell off.
Oh ya and i'm 100% sure I got all the bolts off.
Anyone else ever have this problem? I'm out of time now I have to go to laguna without a baffled oil pan.
Old Jan 19, 2006 | 06:36 AM
Dave_B's Avatar
I've seen them "stick" but the use of a flathead screw driver solved that. The gasket is what's causing the sticking. Try that and see what happens. GL.
Old Jan 19, 2006 | 06:40 AM
RTW DC2R's Avatar
BFH
Old Jan 19, 2006 | 06:47 AM
Batoutahell's Avatar
Default Re: Oil pan won't come off? (ekim952522000)
You might gouge the oil pan or block with a screwdriver. Like RTW DC2R says, BFH never fails. Remove the drain bolt and use the drain hole for purchase and yank down.
Old Jan 19, 2006 | 07:03 AM
andyt's Avatar
Default Re: Oil pan won't come off? (Batoutahell)
Or a BFRM (big f* rubber mallet)
Old Jan 19, 2006 | 08:28 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
Default Re: Oil pan won't come off? (andyt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt &raquo;</TD></TR><TR><TD CLASS="quote">Or a BFRM (big f* rubber mallet) </TD></TR></TABLE>
I would def use a rubber mallet.
Old Jan 19, 2006 | 03:07 PM
gsr-2nr's Avatar
Default Re: Oil pan won't come off? (walker111)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">I would def use a rubber mallet.</TD></TR></TABLE>
Quickest answer to your prob
Old Jan 19, 2006 | 06:08 PM
Default Re: Oil pan won't come off? (gsr-2nr)
ok guys I'll try a big hammer
But I did get my brakes done
lazyxmofo
Mar 9, 2011 06:26 PM
hatchet_honda
10
Aug 22, 2010 08:28 PM
cloud7
Apr 9, 2010 08:47 PM
wdissident
Jan 19, 2009 08:49 PM
dynomax27
Oct 15, 2002 04:22 PM
