My Vtec Kicks in at 4200 RPMs. Good or Bad?
Old Mar 21, 2002 | 06:29 PM
usdm NA 429's Avatar
Default My Vtec Kicks in at 4200 RPMs. Good or Bad?
I got my car tuned on my birthday, which was tuesday. My vtec kicks in at 4200.
My mods are AEM CA, Spoon T.B., Apexi N1, AEM Fuel Rail, AEM Fuel Reg., Is this good, or bad? What's your Vtec at? Is it low as mine?
I was rated at 179.5 hp and 129.8 TRQ.
They mentioned that I need Sprockets and a header and a 2pc head gasket. What's your opinions.
I'm not bragging, I hate people who do so. All I want to know is if its to dangerous for my motor being at 4200 rpms. So please Dont bragg about how good your itr is. Their always someone better. Well thanks for viewing my post.
Old Mar 21, 2002 | 06:30 PM
TypeR0149's Avatar
Default Re: My Vtec Kicks in at 4200 RPMs. Good or Bad? (DC2 #429)
i wouldnt get spacely sprokets, i think Cogswell Cogs are better.
btw I have never seen a VTEC point that low
Old Mar 21, 2002 | 06:33 PM
Rob :190:'s Avatar
Default Re: My Vtec Kicks in at 4200 RPMs. Good or Bad? (Vegeta)
how is the vtec set on your car? did you get an ecu made or something? i dont see anything on your mod list that could change vtec point, but i'm not that bright...
Old Mar 21, 2002 | 06:35 PM
B2FiNiTY's Avatar
You need a header badly.
Old Mar 21, 2002 | 06:37 PM
hybrider's Avatar
Default Re: My Vtec Kicks in at 4200 RPMs. Good or Bad? (Rob1035)
4.2 ? ouuuuuuuuuu
Old Mar 21, 2002 | 06:52 PM
Fat Matt's Avatar
New User
lol!
Old Mar 21, 2002 | 06:54 PM
Default Re: My Vtec Kicks in at 4200 RPMs. Good or Bad? (AllShowNoGo)
oops, I got a vafc.
done's Avatar
get on the dyno, and look at your dip b/4 adn after vtec...
Old Mar 21, 2002 | 06:59 PM
Default Re: My Vtec Kicks in at 4200 RPMs. Good or Bad? (Jordo)
between 4000 and 5000 rpms, its at 100-125 hp then it drops to 100hp between 5 and 5600rpms and it goes straight up from that. My mid range power was 110.9 stock trq. and after was 124.4 HP is at 126.9hp stock and now 142.4
These readings are from 4000 rpms to 6000rpms. \
I was worried that I was too low so I made my vtec kick in at 4700 rpms now.
Any techs out their that can give advice.
Old Mar 21, 2002 | 07:41 PM
J_Edwards's Avatar
4700 is a little bit more normal. The VTEC changeover on the stock B16 and B18c is going to be at 4700, the stock on the Type R is at 5700. I know that with most of the chipped ECU's out there the VTEC is moved down to about 4700. The only way that you can really know what it should be at is to throw it on a dyno and get it tuned. Depending on your AFR you can move the point around to suit your driving style and fuel map. If you haven't really changed your fuel settings or anything like that I personally would go with a 5200 or 5700 changeover.
Old Mar 21, 2002 | 08:07 PM
Splat's Avatar
Collector-o-Guns and Drinker
Can you scan in or otherwise post your dyno plot? Ideally, there should be no dip, or any other obvious change, when VTEC engages. That's the point of moving the VTEC point around - smooooooooth powerband
Old Mar 21, 2002 | 08:16 PM
Default Re: My Vtec Kicks in at 4200 RPMs. Good or Bad? (itr009)
This was my second tunning. My first vafc settings was a smooth powerband, with no vtec dip. Now after professional tunning, my fuel reg was adjusted with an aem fuel reg. Its at 52 psi. I changed the vtec settings to 4700 for normal driving, but when I need the power, I'll go back to the tuned settings at 4200 rpms, At least until I get a header, sprockets, and a 2pc head gasket.
Dont all of you think that its a bit too low?
Well I did take to a good tuner, but I do trust them, I just thought it was way too low but great for quick power pick up. Sorry no scanner, how else can i post my dyno chart, I have two now. Next month I'll go back with the new parts and tuned again. Whish me luck.
[Modified by DC2 #429, 9:17 PM 3/21/2002]
Old Mar 21, 2002 | 08:33 PM
mr2's Avatar
mr2
bad
Old Mar 21, 2002 | 08:45 PM
Yellow3TypeR's Avatar
Mine is set at 4400....I have a dyno plot on my computer, but don't know how to put it in the post. Could anyone help?
[Modified by Yellow3TypeR, 10:56 PM 3/21/2002]
Old Mar 21, 2002 | 08:50 PM
MUGENTYPER's Avatar
are you using feels program?? coz i know some with the same problem.. for me, thats a little bit too early to kick!
[Modified by MUGENTYPER, 5:51 AM 3/22/2002]
Old Mar 21, 2002 | 09:06 PM
hybrider's Avatar
Default Re: My Vtec Kicks in at 4200 RPMs. Good or Bad? (MUGENTYPER)
mr clock work, the b16 xover i beleive is at 5k while the b18c1 is at 4.4k
Old Mar 21, 2002 | 10:18 PM
SpecR_EK's Avatar
New User
Default Re: My Vtec Kicks in at 4200 RPMs. Good or Bad? (hybrider93)
B16 is 5.5k
Old Mar 21, 2002 | 10:46 PM
01TypeR680's Avatar
New User
Default Re: My Vtec Kicks in at 4200 RPMs. Good or Bad? (SpecR_EK)
the lower the vtec the more gas you use(oil too maybe) also if you need the power just rev higher -rob
Old Mar 21, 2002 | 11:46 PM
Ex-ITR5874's Avatar
Default Re: My Vtec Kicks in at 4200 RPMs. Good or Bad? (Yellow3TypeR)
mail me. I`ll put it on my webiste and post it here.
sven@integratype-r.de
RichardDiaz2005
Honda Civic (2001 - 2005)
46
Jul 6, 2007 08:06 PM
Inextricabledrvr
Jun 2, 2004 01:36 PM
killa_lude
Aug 1, 2003 07:01 PM
hooptie157
Apr 2, 2002 11:57 PM
rbdynamics
Oct 10, 2001 01:03 AM
