cracked manifolds
i have a 2 inch hairline crack in my STD manifold, what is the best way to go about fixing this? i know you are not supposed to weld to cast iron but would it be the best way?
its being used on a d16a6 turbo project.
no the first time i heard that, i thought about grinding it a little bit then welding it... but i know you aren't supposed to weld on cast iron... hmm ive never worked with jb weld, can it take the heat?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker »</TD></TR><TR><TD CLASS="quote">Yeah JB weld works..But you can weld on cast iron,</TD></TR></TABLE>
thanks guys, case closed
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 »</TD></TR><TR><TD CLASS="quote">no experience with this... so this is a long shot...
jb weld?
EDIT: manifold can be had at junkyards for like 20 bux.</TD></TR></TABLE> i dont know if i would jb weld my mani. thats real high heat.....but i did use it for my bov and it worked great
jb weld?
stocker2shocker91
Mar 11, 2007 10:36 AM
dank9513
Jun 13, 2003 06:04 PM
