FS: MUGEN ECU for DC2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rene M »</TD></TR><TR><TD CLASS="quote">I can tell you that these Mugen ECU's are great ....
Great price..</TD></TR></TABLE>
double ditto!
double ditto!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ed 341 »</TD></TR><TR><TD CLASS="quote">Is it a simple swap?</TD></TR></TABLE>
You're good to 9100 with stock valvetrain.
Unless you have a 97 (OBD2a) you will probably need an adapter harness.
The Mugen ECU has a 9100 rev limit and is pretty safe with the stock valvetrain. Vtec kicks in sooner ( somewhere around 4300-4800) more linear power.
If you have an ITR and want a bad *** ECU that you just want to pop in and ride, this is it! I remember running up the twisty mountain roads at 'deals gap' a few years back behind ZYGSPEED when his 97 R had this ECU and watch flames pop out his exhaust with every downshift......definitely has some rich fuel mapping!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DvD3 »</TD></TR><TR><TD CLASS="quote">is it like a obd1 ecu or somethin?</TD></TR></TABLE>
Sort of, it only looks for the primary O2 sensor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">
Unless you have a 97 (OBD2a) you will probably need an adapter harness.</TD></TR></TABLE>
1998's are OBD2A aswell, so if you have either of those years you'll be set.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neof69 »</TD></TR><TR><TD CLASS="quote">If you have an ITR and want a bad *** ECU that you just want to pop in and ride, this is it! I remember running up the twisty mountain roads at 'deals gap' a few years back behind ZYGSPEED when his 97 R had this ECU and watch flames pop out his exhaust with every downshift......definitely has some rich fuel mapping! </TD></TR></TABLE>
Haha.....I remember him and his '97 ITR at Expo 1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcar97 »</TD></TR><TR><TD CLASS="quote">I have a 97' cdn spec car. Will the ecu bolt right in and not throw any cels? Is the ecu practical for a daily driver?
Thanks</TD></TR></TABLE>
fuel mileage might suffer a bit if it's as rich as some people state it being, so if you say it's a DD ....then I would definately not use it in that regard if efficiency is important to you and your cat is still installed.....
Great price...had a chance to try it too.... makes good, safe power for basic I/H/E combos.
No, i have one, pimary sensor unplugged, no CEL. This ECU don't need any o2 sensor. Perfect for fitting a WB in primary sensor place.
</TD></TR></TABLE>No, i have one, pimary sensor unplugged, no CEL. This ECU don't need any o2 sensor. Perfect for fitting a WB in primary sensor place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by camlob »</TD></TR><TR><TD CLASS="quote">How about the spoon ecu? How do you guys rate it?</TD></TR></TABLE>
Pretty much the same as the Mugen one....
Rev limit @ 9,000rpm
VTEC set @ 5,100~5,400rpm depending on throttle angle.
JDM idles are apparently set at 1100rpm instead of 800+/- 50rpm. Can't recall if this is the case with the Mugen brain though....
Why this is.... could be due to emissions I dunno....
