Wheel Stud Replacement: 92-96 Prelude
Old Jan 18, 2006 | 08:55 PM
Excelerate's Avatar
Default Wheel Stud Replacement: 92-96 Prelude
I have searched and read some of threads. Some guys have said they notched the hub and slightly shaved the head of the wheel stud to make it slide in easier rather than remove the entire hub. What I want to know is: will that throw off the balance of the hub? any harm to the hub down to the road? will the wheel stud end up breaking/cracking down the road?
Old Jan 18, 2006 | 08:58 PM
SteveoBA8's Avatar
Default Re: Wheel Stud Replacement: 92-96 Prelude (Excelerate)
i hit my wheel stud out with a hammer, in with a few washers+ lug nut .
Old Jan 19, 2006 | 04:56 AM
kulrevon's Avatar
Default Re: Wheel Stud Replacement: 92-96 Prelude (SteveoBA8)
it should not destirb the balance of the hub. when I put in 2 wheel studs I had to do the same thing. I just shaved off as much as I would need to fit past the hub. and air tools help when replacing these.
I never had a problem with one breaking after I put the new ones in. You only shave a little off the head none of the threads/stud itself.
Old Jan 19, 2006 | 07:55 AM
Excelerate's Avatar
Default Re: Wheel Stud Replacement: 92-96 Prelude (kulrevon)
Yea, I know you shave off a minimal amount on the wheel stud and not the threaded part. I'm not as much worried about the wheel stud as I am as doing any damage to the hub... any other opinions?
Old Jan 19, 2006 | 09:37 AM
mgags7's Avatar
guys, studs are meant to be pressed in, hammering will work though
by using washers and a lug nut you are spinning it into place, unless you took special care to not let it spin, but if it did, you ruined the effect of the raised ribs, they are meant to hold it into place
the only real way to do these is to separate the hub and use new wheel bearings when you put it all back in...
Old Jan 19, 2006 | 02:59 PM
Excelerate's Avatar
Default Re: (mgags7)
Any other opinions??
Old Jan 19, 2006 | 03:05 PM
yOnKiNaToR's Avatar
Default Re: (Excelerate)
i did the notch method and it's been good so far. read my post:
https://honda-tech.com/zerothread?id=1395105
streetracer_305
18
Jun 20, 2015 01:59 PM
fit2slo
Honda Fit
Oct 28, 2008 10:56 PM
JDMJunior
Mar 26, 2006 09:34 PM
nEoMuGen
Nov 15, 2003 04:17 PM
