honda crx Interchangeables?
Have a few questions that I couldnt find.
Will 88-91civichb aftermarket exhaust systems fit a 88-91crx?
Will gsr shocks fit on my car? And if they do can i put the 88-91 skunk2 coils on them?
The axle back on the hatches and crx's are the same..But the B-pipe on the hatch is longer by about 5"-6" depending on what exhaust it is..Yes the integra shocks will work on your car,,they are alittle longer then the stock 88-91 shocks though but do work..And you can use any springs made for 88-00 civic/delsol..90-01 integra..,,maybe more..Also if you have a 88 you'll need 89-91 rear lower control arms to run the rear integra shocks.
Mr. Speaker what would you suggest. i have stock gsr shocks and springs from a 98 gsr.
would you put into the 89crx...
stock gsr shocks w/stock gsr springs
stock gsr shocks w/ aftermarket coils/dropped springs
stock crx shocks w/ aftermarket coils/dropped
springs
aftermarket shocks and springs
springs
I would do aftermarket shocks made for your car,with a different spring..Dont get it wrong since those integra shocks/springs are newer,, putting them on your car it will feel more firm and tight but its going to sit a little high..
DJThomas1189
Suspension & Brakes
Apr 28, 2007 04:09 PM
