B16b transmission questions
Old Jan 18, 2006 | 06:33 PM
infumis's Avatar
Default B16b transmission questions
i was just wondering if anyone knew the part number on a sc4 's differential...i want to go see if honda has some for sale but i need the part number off them because they dont know what im talking about when i say a civic type R...thanks
tye
Old Jan 18, 2006 | 06:41 PM
RTI's Avatar
RTI
Default Re: B16b transmission questions (infumis)
I am almost positive it is the same as the itr diff so you can look up that part number. Why do you need to buy one? CTR already has LSD.
Old Jan 18, 2006 | 07:45 PM
infumis's Avatar
i have a b16a tranny, and i want a diff out of a ctr or itr, whichever diff. part number i can get because i want a LSD but dont got ther money for a sc4, and i dont want to buy a phantom grip or anything , i want the factory so i know it will stick with me. thanks
tye
Old Jan 18, 2006 | 08:53 PM
hapexamendios 2.0's Avatar
R.I.P.
Default Re: (infumis)
your not gonna want to pay what they want
Old Jan 18, 2006 | 11:33 PM
RTI's Avatar
RTI
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infumis &raquo;</TD></TR><TR><TD CLASS="quote">i have a b16a tranny, and i want a diff out of a ctr or itr, whichever diff. part number i can get because i want a LSD but dont got ther money for a sc4, and i dont want to buy a phantom grip or anything , i want the factory so i know it will stick with me. thanks
tye</TD></TR></TABLE>
If you have a b16a tranny you will also need to get the final drive. I thought you had a ctr tranny and wanted to replace the lsd. In your case, the final drive will not bolt onto a honda ctr or itr lsd so you need the final drive too. Total cost will not be cheap. You are better of buying a quaife for your tranny since it will work with your existing final drive.
Old Jan 19, 2006 | 09:12 AM
infumis's Avatar
still, i know what i need and i got the final drive, but i want a NEW factory built diff with factory lsd, so if anyone has the part number like the topic was asking it would help me alot thank you
tye
Old Jan 19, 2006 | 07:20 PM
RTI's Avatar
RTI
ITR LSD has a part # 41200-p80-003.
Old Jan 19, 2006 | 08:26 PM
infumis's Avatar
thank you so much.
tye
Old Jan 19, 2006 | 09:03 PM
atomik speed's Avatar
Default Re: (honda 3300)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda 3300 &raquo;</TD></TR><TR><TD CLASS="quote">your not gonna want to pay what they want </TD></TR></TABLE>
no ur not!
Old Jan 19, 2006 | 09:22 PM
fastrunner's Avatar
Default Re: (atomik speed)
b16 and ITR final drive is compatible, you can use a final drive from a b16 with an ITR lsd. you don't buy a new final drive when you get a quaife... same applies to all LSD.
Old Jan 19, 2006 | 09:41 PM
L8apex's Avatar
Default Re: (fastrunner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrunner &raquo;</TD></TR><TR><TD CLASS="quote">b16 and ITR final drive is compatible, you can use a final drive from a b16 with an ITR lsd. you don't buy a new final drive when you get a quaife... same applies to all LSD.</TD></TR></TABLE>Try it.
The final drive ratio between both cars are the same, but the ring gear on the ITR/CTR is different from a B16A. The actual LSD unit is not compatible and will not bolt up to the other's ring gear.
And to the original poster, I got my OEM LSD off eBay from this guy:
http://cgi.ebay.com/ebaymotors...wItem
5,000 km later and no problems. Working normally. Highly recommended.
You do know that you will need the differential bearings from a 98-01 ITR and will need to check the clearances again right?
Old Jan 19, 2006 | 10:46 PM
imports automotive's Avatar
hes right ^^^ is not compatible it doesn't bolt up
Old Jan 19, 2006 | 11:08 PM
RTI's Avatar
RTI
Default Re: (imports automotive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imports automotive &raquo;</TD></TR><TR><TD CLASS="quote">hes right ^^^ is not compatible it doesn't bolt up</TD></TR></TABLE>
I already told this to the orignial poster and he is still interested in getting new oem stuff. He knows he needs diff and final drive.
Old Jan 20, 2006 | 03:07 PM
infumis's Avatar
yea this is done and done, and i knwo what i need, i was jsut asking for a part number, thank you.
huslin
Jul 16, 2010 02:20 AM
Takashi1978
May 10, 2005 06:00 PM
jwyoung
May 3, 2005 05:52 PM
civicdohc
Nov 21, 2003 01:59 PM
b16a1sirhb
Nov 13, 2003 05:00 PM
