Torque specs for a balljoint and swaybar link
Resident Hoser #1
Anyone know the torque specs for the drivers side balljoint (with Upper Control Arm) and the drivers side swaybar link should be. I called all 3 Honda dealers in my city and they gave me a range from 29lbs to 80lbs. It's a bit of a gap there so I'm either guessing there is no real torque specs or they don't know what they are talking about. Anyone know what they should be¿
its a ball joint, when u get to a certain point it will just spin (use air gun to get it to this point)... do it that tight, as for the sway bar... idk
Resident Hoser #1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93h22a1vtec »</TD></TR><TR><TD CLASS="quote">its a ball joint, when u get to a certain point it will just spin (use air gun to get it to this point)... do it that tight, as for the sway bar... idk</TD></TR></TABLE>
No offense but that doesn't sound right. Are talking about the balljoint itself or are you talking about the 2 bolts for the control arm and the lower one? The balljoint and the control arm are pressed already.
i dont know the tq spec but they just need to be turned to stop, then to the next open hole past 1/4 turn more....thats for the ball joint...
i dont know the swaybar link
but check deliii.com for the helms manual, it will have it...
It's 32 ft/lb for the BJ, still have the turn it until you can get the cotter pin through. The sway bar links are tightened down until the rubber is 1/2 it's size.
Digitalsmoke
Aug 8, 2009 05:07 AM
jdmspoonitr
Jan 10, 2005 05:41 PM
