Valve cover gaskets
I'm going to be doing a valve adjustment and wanted to get the valve cover gasket juts in case I need it. Does anyone have the part number for it? I did a search and no one had the part number. Thanks a lot, Ryan.
I dunno the part number. But there's a new site out: http://www.hondrparts.com and they have the valve cover gasket for $6.79 for all model Integras.
Wow, what a coincidence, I happen to have a spare one laying around.
Part Number is: 12341-PR3-000
Now who can give him the part number for the spark plug hole gaskets?
the black "bolt gasket" covers (metal) are a bit cheaper.
the b16's are black and the b18c1/c5 are shiny? didnt know that...but as far as the gasket goes if its old or youve removed the cover a few times than yes you should replace. uf its fairly new you DONT HAVE TO but they reccomend you should. it wont "tear" cause its made of rubber. if you do re-use or even get a new one dont forget to dap a little hondabond or other sealent around the corners.
12342-PG6-000
spark plug gaskets x4
If I have to order 4 of them, thats crazy... they're like 3 bux each!!!
ahmotor.com has the complete valve cover gasket set for $30 something.. it comes with the valve cover gasket, all the grommets, and the tube seals for the spark plug holes
they come in a set of four or u have to order 4 of them????!??!?
even if they were $3.00 each, is $12.00 breaking the bank?
but they're really small things. I just think its an unreasonable price... thats all
ok, can i order a few things from you?? E-mail?
[Modified by zojirushi, 11:09 AM 3/25/2002]
