linkage question
so i have 15 and 14 but i dont have 9. do i need it? 15 holds the top of the shifter ball, so what keeps the shifter from falling. does the end of 15 come into the interior or stay below the floor? This is an auto to manual swap so i really dont have the normal manual hardware, just what ive collected.
15 says under the car. The boot (#7) that goes onto part of 15 should to inside of the car (but you don't HAVE to have it)
YOU WILL NEED #9!
#9 holds the shifter from falling out of #15. They are special bolts that you used and pictured, but if you must, you can get away with using some generic bolts. However, since you have for order #9, order (2) of 22, (2) of 28 and (2) of 20
YOU WILL NEED #9!
ya im pretty sure you need 9 cuz i do believe it holds up the shifter. if i can remember right from doing it not to long ago. but someone can correct me if im wrong. good luck
yah i didnt have a shifter so i bought a trasher on ebay, it has the internal bearings, the outside washers the bolt and the nut.
looks like i need the bushing for the rear "arm" of the linkage and part #9 with the bolts. if anyones got them ill be happy to alleviate you of them...
jpnucrx
46
Dec 2, 2008 10:22 PM
fujiwara takumi
Sep 12, 2006 06:42 PM
wdskuk
Feb 13, 2004 03:54 PM
