How to remove climate control radio bezel 96-98 Civic hatchback
damn bro you killed that thing! haha well my 00 ek had some clips all around but wasnt that hard to remove.
no thieves killed that thing.. there are screws in the back of the bezel.. iono how to get to it so i was trying to remove the bottom part of the dash so i can try and unscrew them.. but iono how to remove it..
there is a screw behind your hazard light switch and your rear windowdefroster. And i think there might be some behind the panel for your power outlet. Then it just is held on by clips
pop the hazard and defroster buttons out (not the buttons but the plastic around them), there are screws behind them. You might need to drop the plastic piece where the cigarete lighter is (I'm not totaly sure), there might be some screws over there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinoyboiwonder »</TD></TR><TR><TD CLASS="quote">but isnt there a wire.. in back of it and also a screw to hold it in place?</TD></TR></TABLE>
yeah you fucken unplug the connector once you pry the fucken button (not just the round button but the plastic around it). This is getting fucken horrible, just do as we say don't hurry and you will be perfectly fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeaLevel »</TD></TR><TR><TD CLASS="quote">yes you have to drop the panel with cig lighter. after dropping that, look up and you'll see the screws for the climate control bezel</TD></TR></TABLE> There are six screws to remove to take this panel off. After that, Look up and you'll notice four nuts. Take those off, and the whole consol should pull right out. I've done it many times, my car had the same problem after it was stolen. Don't pry anything, you'll only mess it up worse. Aslo, you shouldn't need to remove the lower compartment.
Brake_Check
Dec 18, 2013 10:29 AM
matt94z
Audio / Security / Video
Feb 15, 2009 10:58 AM
deez nuts
Jan 20, 2005 03:30 PM
SPOONfdEK
Jun 5, 2003 01:30 PM
