accord 91 cooling fan problem really weird
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
ok this 91 accord i'm working on has a fan prob...i changed both temp sensor's the relay, and fuse's the fan work's being tested with power direct...but still doesn't come on when the car heat's and start's to overheat..when i turn the car off the damn fan comes on wtf?....any idea's thnxs
One of the fan switches is responsible for running the fan when the engine's on, probably it's in the thermostat housing? Does the fan run when you jumper the wires for that switch?
You say you changed the fan relay, but did you check the fan timer module? That's not the same thing as the fan relay.
oh yeah... I didn't think the main relay is associated with this circuit at all... Got a wiring drawing?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DBL »</TD></TR><TR><TD CLASS="quote">ok this 91 accord i'm working on has a fan prob...i changed both temp sensor's the relay, and fuse's the fan work's being tested with power direct...but still doesn't come on when the car heat's and start's to overheat..when i turn the car off the damn fan comes on wtf?....any idea's thnxs
I have the SAME problem.. except mine doesnt over heat. but when i turn the key off the other fan comes on.
mine is a 90 accord with a boosted h22. no clue what the problem is but so far i havent had it over heat.. i just noticed its weird that it only comes on when the key is off
</TD></TR></TABLE>I have the SAME problem.. except mine doesnt over heat. but when i turn the key off the other fan comes on.
The fan switch at the upper radiator hose nozzle is responsible for switching the fan when the engine's turned off. The one that's responsible for switching the fan when the engine's running, is in the thermostat housing. Or maybe for certain years/models that switch is on the back of the block somewhere.
well i just wired it up to straight power but i'll look for the timer ..maybe the temp sensor in the back that i replaced is bad to..**** never know i'll check it out thnxs for the reply's
i replaced it again still samething ...were is the timer located ? and is there anymore relays that may effect the fan i also noticed his power windows don't work and the seat belts. changed the relay's and fuse's for the PW still dead...maybe this car has sexual problems
My accords don't have that 2-sensor & timer system, so I don't know where the timer is hidden.
Actually, I think there's been some threads in the Accord forum; search for fan timer module. Seems to me someone posted a wiring drawing scanned from the Helm book?
sorry to bring up old threads but i fixed this problem...i know some people had the same prob...after changing the cool sen temp,relays..and fuse's it all came down to the damn ECU..changed it and everythinhg works fine..fan come's on time and car isn't over heating ...so try that if you have a prob like mine...
peace
DBL
peace
DBL
Jdmsolutions
Nov 16, 2006 12:47 PM
August Burns
Jan 21, 2005 09:02 AM
