GARAGE SALE - Schaumburg, Lombard (Chicago Suburbs) IL / Illinois
<FONT COLOR="33CC00"><FONT SIZE="3">Most prices are obo</FONT></FONT>
<FONT COLOR="red">Everything is in excellent condition
Contact me if you need more info about something
I prefer local pick-up, but will ship at buyers expense.</FONT>
OEM Radiator Fan - $30
Complete Engine head - $75
-Removed from a '97 DX, d16y7 w/86,XXX miles
OEM Cam gear - $15
-Removed from a '96 EX, d16y8
Upper O2 sensor - $50
Free-flow cat converter - $65
1996-2000 EX resonator/test-pipe (might fit others)
with 02 sensor installed (can't be removed)
Automatic transmission - $100
-Works great, but makes a little wining noise (input shaft bearing might be going)
Starter for Auto-trans - $45
Alternator - $35
Underdrive crank pulley (NEW) - $50
1992-1995 SOHC CIVIC
Driver side axle - $55
Purchased from autozone 1-2K miles ago (used for a month)
Konig hub rings - $5 each
One rear LCA (not a pair) - $5
Cruise Control - $55
-Everything that’s under the hood
Cruis control bottons - $20
-Makes for a clean looking n2o swithc
Power steering pum + reservoir can - $55
Heater core - $100
A/C - $100
-Includes: A/C Compressor, A/C compressor brackets, A/C Idler pulley,
A/C condenser, All lines and sensors
Fuel injectors - $20
-From '97 LX (d16y7)
-Fuel rail/psi regulator sold separately
-From '97 DX (d16y7)
Fuel rail - $10
1997 civic LX
Fuel rail - $10
1997 civic DX
Fuel PSI regulator (OEM) - $15
Fuel PSI regulator (OEM) - $20
-From '96 EX (d16Y8)
Intake Manifold (bare) - $20
Intake parts - $5 each
-I don't know what it is, came with an aftermarket air intake
K&N 2.75" conical, reusable air filter (used) - $35
Intake - $35
-Removed from 1997 LX (d16y7)
Intake - $35
-Removed from 1997 DX (d16y7)
Intake air temperature sensor - $25
Throttle cable - $5
EVAP sensor - $40
EVAP sensor - $40
P2E ECU - $40
-From '97 LX (d16y7) auto
P2E ECU - $40
-From '97 DX (d16y7) auto
New KMS block guard - $55
Spark plug wires - $30
-Used 9.3mm APC
Spark plug wires - $50
-NEW 10.3mm OBX-R
Complete engine wire harness - $100
-Removed from a 1997 LX (d16y7)
Complete headlight wire harness - $50
Complete front dash - $150
-Type K, Light Grey
-Includes: Dashboard, Gauge bezel, Dim switch,
Cruise control switch, Wire harness, All vents,
Lower driver side panel, Power mirror switch, Fuse cover,
Lower middle panel, Power outlet, Glove box, Side panels (end-caps),
Steering column panel, "A" pillars, Kick panels, All brackets
Center console - $80
Includes: Black center console trim, Two middle vents,
Window defrost and Hazard light switches, Coin tray, A/C controls,
Adapter plate for aftermarket radio, I can also include all wire plugs
Stock AM/FM radio w/rear speakers - $40
-I can include a complete wire harness for an extra $30
1.0frd Capacitor w/digital voltmeter - $65
Two 10” subwoofers w/ban pass box - $225
Rockford Fostgate
RFP3410
400W Max (200W RMS) 4ohm (each)
ProBend competition banpass R/T box
red neon in the box
Amplifier - $20
Sony 30W x 2 bridgeab amplifier
MX-3021 Mosfet
20-20KHz 0.04% T.H.D 4ohm
Three 6.5" infinity speaker grills - $10
Arm rest - $80
-Type K, Light Grey
-Includes: Complete arm rest, Cup holder,
Shifter console, Brackets
Arm rest eliminator - $30
-Dark Grey
DX gauge cluster - $30
Mini tachometer - $25
N2O pressure gauge - $25
Rear view mirror (inside/center) - $15
Rear view mirrors (side/outside) - $50
-Non power side mirrors
-Will fit 96-00 coupe/hatchack
Dome Light - $10
Parking brake handle/lever - $10
Handles (roof) - $50
Front passenger seat - $50
Front seat uphostery - $50
-Removed from a 2000 civic Si
-Shows some wear on driver seat lower part, nothing ubnormal
-perfect if yours are riped/torn/burned...whatever
Front door handles - $20
-used, unpainted
Front upper grill - $35
-DIY GBP grill for 96-98 civic
Headlights - $100
-Factory headlights for 96-98 civic
Driver-side taillight - $30
Altezzas - $25
96-00 civic hatchback Altezzas
Taillights - $60
-Factory taillights for 96-98 hatchback
Cargo Cover - $100
-96-00 civic hatchback custom cargo cover
Inner trunk panel - $30
Rear license plate panel - $30
License plate lights - $20
Gas tank cover (GBP) - $15
Gas tank cover (chrome w/CF insert) - $50
Rear shelf - $30
-Type K interior, Light Grey
Trunk Vent - $5
Trunk Light - $10
Bumper Guards - $50
-These came on the car from O'hare Honda dealer
-Three are good, but one is torn where the car was hit
-Would need new double stick tape to reattach them.
Mud guards - $40
-Some usual scratches
-all mounting brackets/bolts included
Side-skirts - $35
-Some scratches
-mounting brackets included
Antenna - $15
Windshield wipers - $10
Eyelids - $10
Mugen style eyelids for '96-'98 civic
Painted Granada Black but need to be repainted
Front Shocks - $30
-Front OEM struts
-Forks
-Dust covers
-bump stops
-OEM Springs
-Upper stut mounts
Enkei rims w/NT555 tires - $900
-17" Enkei RF-1 rims w/OEM centercaps
-205/40-17 Nitto NT555 ZR tires
Rims w/winter tires - $350
-14" Black steel rims made by Unique (like new)
-W404 winter tires (like new)
I'm selling my PS2 games, memory card and a light gun - <FONT SIZE="2"><FONT COLOR="red">$60</FONT></FONT> for all of it.
1. Gran Turismo 4
2. Gran Turismo 3
3. Auto Modelista
4. Ridge Racer V
5. Gadget Racers
6. PS2 Sony 8MB memory card
7. PS2 light gun w/recoil action and laser sight
Modified by d16rice at 8:21 AM 7/7/2006
OEM Cam gear - $15
Alternator - $35
Heater core - $100
A/C - $100
Fuel rail - $10
1997 civic LX
Fuel rail - $10
1997 civic DX
Intake - $35
Intake - $35
Throttle cable - $5
EVAP sensor - $40
EVAP sensor - $40
P2E ECU - $40
P2E ECU - $40
-Used 9.3mm APC
-NEW 10.3mm OBX-R
-Type K, Light Grey
Rockford Fostgate
RFP3410
red neon in the box
Amplifier - $20
MX-3021 Mosfet
Arm rest - $80
-Type K, Light Grey
-Dark Grey
Dome Light - $10
-used, unpainted
Headlights - $100
Altezzas - $25
Taillights - $60
Cargo Cover - $100
Rear shelf - $30
Trunk Vent - $5
Trunk Light - $10
Bumper Guards - $50
Mud guards - $40
Side-skirts - $35
-Some scratches
Antenna - $15
Eyelids - $10
Front Shocks - $30
-Front OEM struts
-Forks
-Dust covers
-bump stops
-OEM Springs
-Upper stut mounts
1. Gran Turismo 4
2. Gran Turismo 3
3. Auto Modelista
4. Ridge Racer V
5. Gadget Racers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16rice »</TD></TR><TR><TD CLASS="quote"><FONT SIZE="3">PARTS FOR SALE</FONT>
1994 civic rear sway bar
(swaybar/endlinks/brackets/bushings)
Includes almost everything needed to install it
$60
Modified by d16rice at 3:43 PM 1/22/2006</TD></TR></TABLE>
will this fit to a 99 ek hb ??
2. how much will it coast to ship it to israel?
thank you
$60
thank you
Replied
If anyone wants to meet up and buy/trade parts during the next Chicago meet, IM me.
It's all game as long as I can fit in on my back seat.
I'm looking for:
Complete 99-00 Si REAR sway bar.
I'm looking for:
There's thirty two bottles of beer on the wall,
You take one down and turn around
There's.... ah ....thirty four, no..., thirty tWo bottles of beer on the wall.
bought by me
