I cut my wire harness on my corner lights....help please.
Old Jan 18, 2006 | 05:35 AM
b20eg9's Avatar
Default I cut my wire harness on my corner lights....help please.
I know someone can help me. Okay yesterday i got the jdm corner lights for my eg9. i must have been trippin cuz i cut the oem wire harness and tryed to hook up the jdm wire harness. Anyways after the jdm harness didnt work i noticed that the oem harness fit perfect in the jdm corner light,however; now on one side of my car (the side where i cut the oem wire harness) i have freakn speed blinker. that crap is hella wack and i need to get rid of it today. I wired the stock harness right up green wire red wire and black but maybe i did something wrong?????? please help....
Old Jan 18, 2006 | 06:50 AM
b20eg9's Avatar
Default Re: I cut my wire harness on my corner lights....help please. (b20eg9)
please helpppp......
Old Jan 18, 2006 | 07:47 AM
Jer00si's Avatar
Have you tried to put the old corner light back in? Does this cure the speed blinker problem? I haven't messed with my Civic lights, but my Jeep will do this until it's screwed in place which grounds the light. Sounds like it could be a ground issue.
Old Jan 18, 2006 | 08:12 AM
pdiggitydogg's Avatar
if its wired correctly, and you soldered (or at least taped) the individual wires, check the bulb and the fuse
Old Jan 18, 2006 | 08:28 AM
b20eg9's Avatar
Default Re: (pdiggitydogg)
I have the same light bulbs(oem blub and harness) in the corner lights but different corner lights(jdm ferio eg9).. all i did was basically cut the 3wires and then put them back together. is a soldered the thing they use to connect speaker wires? and will a bulb that is goin out cause a speed blinker?
I also forgot to mention that the turn signal doesnt even blink in the corner light only in the rear tail lights, maybe that can help yall a lil????
Old Jan 18, 2006 | 08:48 AM
nx2kjl's Avatar
Check the bulb. Also check to make sure that you have the wires spliced together correctly.
Old Jan 18, 2006 | 09:04 AM
Jer00si's Avatar
Default Re: (nx2kjl)
Take the bulb out of the other side that works correctly and put it in the one that isn't working. Did it fix it?
Old Jan 18, 2006 | 09:29 AM
b20eg9's Avatar
Default Re: (Jer00si)
I will do that. i cant do it till later still at work but i will try that. Thanks yall. any other suggestions.
Old Jan 18, 2006 | 10:06 AM
no, solder is...solder. Its metal that you melt on the wires to make a secure connection.
I dont know what youre talking about for speaker wire connectors (quick connects maybe?)
Old Jan 18, 2006 | 11:36 AM
b20eg9's Avatar
okay thanks people. i will be posting the outcome of everyones suggestions so check back if you will to help me out. Thank yalll.
spoolinvtec54
Engine Management and Tuning
11
Feb 13, 2020 09:45 AM
etrent777
Honda Civic (2006 - 2015)
Mar 22, 2014 11:38 AM
07taffysi
Jun 16, 2008 07:24 PM
hitekper4mance
Oct 9, 2007 08:21 AM
soberstan
Oct 1, 2005 10:05 PM
