*****sway bar endlinks help!!!****
Old Jan 17, 2006 | 07:46 PM
1dumbscreenname's Avatar
Default *****sway bar endlinks help!!!****
so my 99-00 si sway bar on my 96 coupe is rubbing the exhaust pipe and creating a hell of a noise. does anyone have any suggestions to fix this problem? I dont want to redo the pipes if at all possible.
its a 3in exhaust btw.
Old Jan 17, 2006 | 08:15 PM
Default Re: *****sway bar endlinks help!!!**** (1dumbassscreenname)
bmp any ideas?
Old Jan 17, 2006 | 08:51 PM
cxSHOE's Avatar
try looking at your muffler hangers. getting a smaller one will fix the probably. i had a similar problem on my 26mm sway bar.
basically the small rubber hanger is the one located at the axle back connection. and the rubber hangers at the muffler are longer. just get two small ones for the muffler and it should push the muffler up and making the exhaust pipe out of the way of the end links...
but i guess this depends on if your piping is not bent, and depends on what exhaust system you have inorder for it to work... but its an idea you can play with.
Old Jan 17, 2006 | 09:46 PM
EK k kay's Avatar
Default Re: *****sway bar endlinks help!!!**** (cxSHOE)
I wrapped the part of the swaybar that was hitting the exhaust with some piece of cloth and then wrapped that with foil.
Old Jan 18, 2006 | 08:20 PM
Default Re: *****sway bar endlinks help!!!**** (EK k kay)
Thanks guys i will try to use the hanger idea and see if it works.
Old Jan 18, 2006 | 08:28 PM
R-Lug's Avatar
or get something non-flammable and put btw pipe and sway bar
jrodri1018
Mar 10, 2020 08:47 PM
square_1
Jan 27, 2009 06:35 PM
obuhmyuh
15
Jun 5, 2008 12:30 PM
RedRocketDX
Suspension & Brakes
Jul 17, 2007 05:38 PM
andrew dc
20
Mar 31, 2003 11:01 AM
