*****sway bar endlinks help!!!****
so my 99-00 si sway bar on my 96 coupe is rubbing the exhaust pipe and creating a hell of a noise. does anyone have any suggestions to fix this problem? I dont want to redo the pipes if at all possible.
its a 3in exhaust btw.
Re: *****sway bar endlinks help!!!**** (1dumbassscreenname)
try looking at your muffler hangers. getting a smaller one will fix the probably. i had a similar problem on my 26mm sway bar.
basically the small rubber hanger is the one located at the axle back connection. and the rubber hangers at the muffler are longer. just get two small ones for the muffler and it should push the muffler up and making the exhaust pipe out of the way of the end links...
but i guess this depends on if your piping is not bent, and depends on what exhaust system you have inorder for it to work... but its an idea you can play with.
Re: *****sway bar endlinks help!!!**** (cxSHOE)
I wrapped the part of the swaybar that was hitting the exhaust with some piece of cloth and then wrapped that with foil.
square_1
01-27-2009 06:35 PM
andrew dc
20
03-31-2003 11:01 AM
