JDM CONVERSION OWNERS...how do u make the little wedge bulb turn on?
Old Mar 21, 2002 | 02:22 PM
JDM_ITR's Avatar
Default JDM CONVERSION OWNERS...how do u make the little wedge bulb turn on?
I was wondering how do you make the little wedge bulb in the high beam housing turn on? Which wire connector is it on the harness on the back of the headlight that turns this bulb on and which wire did you hook it up on your ITR to make it work? Anybody have pix of this light on? Thanks
Old Mar 21, 2002 | 02:49 PM
FusionITR's Avatar
Default Re: JDM CONVERSION OWNERS...how do u make the little wedge bulb turn on? (JDM_ITR)
parking light wire
Old Mar 21, 2002 | 04:50 PM
JDM_ITR's Avatar
Default Re: JDM CONVERSION OWNERS...how do u make the little wedge bulb turn on? (FusionITR)
Do you know which prong it is on the harness on the back of the JDM healight?
Old Mar 21, 2002 | 04:52 PM
AllMotorITR's Avatar
New User
Just looking at your signature.. You have LS/VTEC in your R?
Old Mar 21, 2002 | 09:28 PM
98R-1144's Avatar
It's the prong w/the light green wire. Just tap into the parking light lamp wire. Good luck!
Old Mar 22, 2002 | 11:24 AM
JDM_ITR's Avatar
Default Re: JDM CONVERSION OWNERS...how do u make the little wedge bulb turn on? (98R-1144)
Thanks for the help guys...and yup, Im running an LSvtec setup.
Old Mar 24, 2002 | 09:35 PM
JDM_ITR's Avatar
Which parkin lamp wire? I tried hooking it up to the OEM bumper light wires, but then when i turn on the turn signal it middle of the JDM headlight blinks also. That looks kinda funny. Which wire can i hook it up to so that it only turns on when u turn on the parkin light but doesnt blink?
Old Mar 24, 2002 | 10:15 PM
98R-1144's Avatar
Which wire you tap is dependent on what year your Integra is.
I believe all 98+ Integras...if you get the JDM front done... your sidemarkers don't blink. They are just basically parking lights (2 wires)... so for the city light... just tap that power wire.
On the pre 98 Integras.. if you get the JDM front... I believe the sidemarkers will stay on AND blink on signals. That means it will have 3 wires... one LOW power (for parking lights), one HIGH power (for signaling), and one ground. You need to tap the LOW power to the city light if you just want it to turn on w/the parking lights.
Good luck!
Old Mar 25, 2002 | 06:49 PM
t's Avatar
t
Red with black stripe.
Old Mar 25, 2002 | 08:52 PM
JDM_ITR's Avatar
Thanks everyone...i found that black wire with red stripe. Its the wedge bulb on the tail lights. Is there anywhere i can find that wire nearer to the front of the car? I dont feel like running a wire all the way to the back.
Old Mar 25, 2002 | 08:54 PM
t's Avatar
t
It should already be at the front of the car at the turn signal.
Old Mar 25, 2002 | 09:18 PM
JDM_ITR's Avatar
Default Re: JDM CONVERSION OWNERS...how do u make the little wedge bulb turn on? (t)
front of the car? where is it? the stock bumper lights blink....unless im not seeing a wire. I only know of the black, red stripe wire on the rear tail light.
Old Mar 26, 2002 | 10:22 AM
JDM_ITR's Avatar
Default Re: JDM CONVERSION OWNERS...how do u make the little wedge bulb turn on? (fuzznuts)
its easy...all you have to do is remove the circular light gray high beam cover by twisting it off.....and its right behind there.
Old Mar 27, 2002 | 12:08 PM
t's Avatar
t
You should have a parking light up in the front that turns on when you turn the parking lights on. Red with a black stripe.
crxguy406
Mar 6, 2011 03:36 PM
vthree
May 6, 2006 03:56 PM
everafter
Jan 4, 2004 07:23 PM
HoNdAeX11
Jul 21, 2003 02:53 PM
