best ignition timing on a d16z or best way to find it with out a dyno
Old Jan 17, 2006 | 05:32 PM
Psswrdjdm318's Avatar
Default best ignition timing on a d16z or best way to find it with out a dyno
i have a d16 in my ej1 , and i wanted know the best way or the best ignition timing degree for it without a dyno, also same question for the cam timing with adjustable skunk2 cam gears?????
Old Jan 17, 2006 | 05:36 PM
Padawan's Avatar
Darth ModerVader
Default Re: best ignition timing on a d16z or best way to find it with out a dyno (Psswrdjdm318)
There is really no way of determining the ideal settings without a dyno, so your best bet would be to set the ignition timing within factory specs and leave the cam timing at 0,0.
Old Jan 17, 2006 | 05:45 PM
Default Re: best ignition timing on a d16z or best way to find it with out a dyno (Padawan)
well is there nething esle i can do to this thing with out spending to much money to get a lil more power out of it?...............................and if u have herad of this my engine like surges when it is cool until it gets warm ussually takes it like 3 or 4 minutes, it goes up and down between 1000 2500, after a few it disappears and runs fine
Old Jan 17, 2006 | 05:47 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Psswrdjdm318 &raquo;</TD></TR><TR><TD CLASS="quote">i have a d16 in my ej1 , and i wanted know the best way or the best ignition timing degree for it without a dyno, also same question for the cam timing with adjustable skunk2 cam gears?????</TD></TR></TABLE>
1). You don't have gears on a SOHC engine
2). There is no magic "one number fits all" setting
3). Run stock ignition maps, work from there
4). SOHC's typically favor 2 degrees retarded. Again, this will not apply to ALL engines.
Old Jan 17, 2006 | 05:59 PM
Default Re: best ignition timing on a d16z or best way to find it with out a dyno (Hybrid93Eg)
alright i know i dont have "gears" i meant gear but, but a 2 degree retartd, is that toward the firewall or front of the car?
Old Jan 17, 2006 | 06:14 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Psswrdjdm318 &raquo;</TD></TR><TR><TD CLASS="quote">alright i know i dont have "gears" i meant gear but, but a 2 degree retartd, is that toward the firewall or front of the car?</TD></TR></TABLE>
Read your gear. Its clearly labeled. Remember, this is not a one setting fits all. Adjust at your own risk.
Old Jan 17, 2006 | 06:56 PM
x_outlaw_x's Avatar
if you dont know which way advance or retard is i honestly dont think you should be messing with something like that
beaterdriver
May 25, 2004 08:03 PM
luckypon7
Apr 9, 2004 06:35 PM
SIReg9
Oct 23, 2002 12:25 PM
