Are there different blocks for H23A1 engine?
Hi:
I have a '93 Honda Prelude Si with an H23A1 engine. I'm having my engine switched out for another H23A1. Are all H23A1 engines alike or are there those with different blocks (e.g. higher/lower nickel content depending on manufacturer) or any other differences I should be aware of?
Thanks for your input.
They are all the same. Hell, you could even go with a 93-97 H22 block. They are identical.
98+ blocks have the 55mm mains.
Ok, thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD »</TD></TR><TR><TD CLASS="quote">They are all the same. Hell, you could even go with a 93-97 H22 block. They are identical.
98+ blocks have the 55mm mains. </TD></TR></TABLE>
