Which cat to use? JDM 4-1 & RSR ex-mag
Old Jan 17, 2006 | 02:04 PM
DOHCtorTHRUST's Avatar
Default Which cat to use? JDM 4-1 & RSR ex-mag
ok, i purchased the ex-mag several months ago and its been sitting in my room for quite some time. the same goes for the 4-1. i am now in search for a cat that will work with this combination on my EG without modification to both the exhaust or the header.
what are most of you guys running on? i believe the ex-mag is 2.25in but the 4-1 is 2.5in. i need something that will tie these two together.
Old Jan 17, 2006 | 04:26 PM
Default Re: Which cat to use? JDM 4-1 & RSR ex-mag (DOHCtorTHRUST)
wow, no one has an answer to this?
Old Jan 17, 2006 | 05:41 PM
Jedi_Sol's Avatar
http://www.kteller.com
Sells a custom high flow cat that is 2.25" on one side and 2.5" on the other for about $140(?). Then just order whatever flanges you need to match the header and exhaust to the cat. You should be good to go.
James
Old Jan 17, 2006 | 07:54 PM
Default Re: Which cat to use? JDM 4-1 & RSR ex-mag (Jedi_Sol)
yeah, but would they fit under the EG chassis? thats my main concern, i might have to go to a muffler shop...thanks for the reply
djtony5
Sep 24, 2005 02:54 PM
NAB16AEK
Jan 16, 2004 07:20 PM
Integrity
Jun 26, 2003 04:35 AM
pennies_hatchie
Jan 27, 2003 02:18 PM
FusionITR
Mar 23, 2002 10:52 AM
