JDM D15B is bucking... Something about EACV?
Old Jan 17, 2006 | 01:48 PM
Ding's Avatar
Default JDM D15B is bucking... Something about EACV?
Well my friend swapped out his D16Z6 for a JDM D15B vtec motor and he has been having issues with the eacv. He think that this is messing with his idle and it isn't hooked up right. How would he go about hooking this up right?
Old Jan 17, 2006 | 01:51 PM
A.S.I.M.O's Avatar
Default Re: JDM D15B is bucking... Something about EACV? (90CRXLS)
what ecu is he using?
Old Jan 17, 2006 | 02:44 PM
Ding's Avatar
Default Re: JDM D15B is bucking... Something about EACV? (A.S.I.M.O)
His stock one. I guess its the P28. He had a Z6 in his car and that motor was beat so he got this and he has been having minor issues with it ever since.
Old Jan 18, 2006 | 11:33 AM
Ding's Avatar
Bump.
Old Jan 18, 2006 | 02:02 PM
Ding's Avatar
Bump
Old Jan 18, 2006 | 02:04 PM
DeathByBoost's Avatar
70.171.124.31
I think the P28 doesn't work with the Japanese D15. Also it's the IAC valve. Try cleaning it out.
Old Jan 19, 2006 | 04:44 AM
Ding's Avatar
Default Re: JDM D15B is bucking... Something about EACV? (DeathByBoost)
Yea I don't know what the hell is going on. I just know that his idle is really messed up between 900 and 2000 rpms. The P28 does work with the JDM D15 from what I have read. Will the knock sensor need to be wired or is this caused by another issue?
Old Jan 19, 2006 | 11:56 AM
Ding's Avatar
Bump. Need help as this is his daily driver.
Old Jan 19, 2006 | 12:02 PM
mc's Avatar
mc
the p28 will work fine. Is it throwing any cels? If you think it is the iacv then you can try taking it off and cleaning it.
Old Jan 19, 2006 | 01:40 PM
Ding's Avatar
Default Re: JDM D15B is bucking... Something about EACV? (mc)
It is throwing CELs. It is the Tap sensor CEL or the EACV sensor CEL. Do you have a solution for both?
Old Jan 19, 2006 | 03:54 PM
mc's Avatar
mc
"TAP"? Do you mean tps? Maybe you guys switched the map and tps plugs by accident since they are right next to each other and are the same plug. Double check that the wire colors going to the TPS are Yel/Wht - Red/Blu - Grn/Wht. And that the wires to the map sensor are Wht - Grn/Wht - Yel/Red. Hope this helps
Old Jan 20, 2006 | 09:10 AM
Ding's Avatar
Thanks man we will check. He used his stock harness, so all the plugs go where they reach. Should he have swapped out the harness?
Old Jan 20, 2006 | 09:20 AM
mc's Avatar
mc
No you shouldn't have to do anything to the harness just switch the plugs. They are close together and can be mixed up easily
Old Jan 20, 2006 | 01:34 PM
Ding's Avatar
Even on the stock harness they are close? We tried the other night and there was no way the one plug was reaching the full length to plug somewhere else.
310HPS2k
24
Oct 12, 2009 10:22 PM
poncejose334
Oct 9, 2009 01:42 PM
Spoon84
Jun 20, 2009 08:17 AM
SkoundrelUSA
29
Nov 10, 2005 06:28 PM
Spraying93
23
Dec 29, 2003 01:45 PM
