how do you remove ej2 sideskirts???
Old Jan 17, 2006 | 01:23 PM
.BigSexy's Avatar
most hood white kid
Default how do you remove ej2 sideskirts???
probably some easy question, BUT after the driver side one fell off, I was gonna do the ek sideskirt swap...but I can not get the passenger side one off for the life of me. all of the screws in the bottom of them have been removed, and they still will not come off...anyone got anything?
Old Jan 17, 2006 | 02:07 PM
-Gambit-'s Avatar
Default Re: how do you remove ej2 sideskirts??? (egcoupe94)
make sure al the screws at the bottom are out, then there is one maybe 2 in the front wheel well. Then just push the entire skirt towards the front wheel and its off
Old Jan 17, 2006 | 02:26 PM
.BigSexy's Avatar
most hood white kid
Default Re: how do you remove ej2 sideskirts??? (-Gambit-)
all of them are out, even the ones in the front. I had to take the fenders off so I know I got those out...but when you say push the skirt, I tried that, I jsut may not have been pushing hard enough. ehh...its took wet outside to do it....damn rain!
Old Jan 17, 2006 | 02:28 PM
-Gambit-'s Avatar
yep you have yo push it towards the front wheel.
Old Jan 17, 2006 | 02:33 PM
.BigSexy's Avatar
most hood white kid
thanks for the help bro...I just felt that I was gonna push it too hard and break something...
Old Jan 17, 2006 | 02:34 PM
-Gambit-'s Avatar
there is about 8 little plastic clips that the skirt slides into
Old Jan 18, 2006 | 07:51 AM
civicseth's Avatar
I thought you pushed it towards the rear of the car? Either way, once the screws are out, slide the skirt and then it will pull off, leaving the clips in the body of the car.
Old Jan 18, 2006 | 10:25 AM
.BigSexy's Avatar
most hood white kid
on another note...do you are the clips the saem on the ek sideskirts...like I said, I am going to swap them...
Old Jan 18, 2006 | 11:47 AM
RWOL's Avatar
a pry bar and a 5lb sledge
Old Jan 18, 2006 | 02:02 PM
.BigSexy's Avatar
most hood white kid
Default Re: (h22crxoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxoner &raquo;</TD></TR><TR><TD CLASS="quote">a pry bar and a 5lb sledge
now follow these directions...get someone to hit you over the head with that 5 lb. sledge...
Old Jan 19, 2006 | 06:44 PM
civicseth's Avatar
Confirmed: slide forward.
Old Jan 19, 2006 | 08:58 PM
.BigSexy's Avatar
most hood white kid
Default Re: (civicseth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicseth &raquo;</TD></TR><TR><TD CLASS="quote">Confirmed: slide forward.</TD></TR></TABLE>
thanks buddy...
Old Jan 19, 2006 | 10:51 PM
qat727's Avatar
Default Re: (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">
thanks buddy...</TD></TR></TABLE>
make sure you got all those little plasic clips out as well. It won't slide anywhere with them in. Once you get them all out, you ought to be able to pull the skirt down a bit and slide it.....
Old Jan 20, 2006 | 05:36 AM
.BigSexy's Avatar
most hood white kid
Default Re: (qat727)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qat727 &raquo;</TD></TR><TR><TD CLASS="quote">
make sure you got all those little plasic clips out as well. It won't slide anywhere with them in. Once you get them all out, you ought to be able to pull the skirt down a bit and slide it.....</TD></TR></TABLE>
you cant get those clips out with the sideskirt still on there right? and you are talkiking about the white clips...
Old Jan 20, 2006 | 03:44 PM
qat727's Avatar
nah.... not the white ones..... underneath the sideskirt, there are black plastic screw thingies.... you have to use a phillips and screw the center part out, then you just pull the expanding part out and you're good to go.
Old Jan 20, 2006 | 05:04 PM
.BigSexy's Avatar
most hood white kid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qat727 &raquo;</TD></TR><TR><TD CLASS="quote">nah.... not the white ones..... underneath the sideskirt, there are black plastic screw thingies.... you have to use a phillips and screw the center part out, then you just pull the expanding part out and you're good to go.</TD></TR></TABLE>
yeah, I know what you're talkin bout matt. I got all of those, thats why I was puzzled cuz it wouldnt come off....
hondafitdad
Honda Fit
May 7, 2019 03:13 AM
ls-vtEK4
Apr 6, 2007 08:32 AM
Jonnyr4c
19
Jun 27, 2006 06:40 PM
payneth
Dec 19, 2003 09:23 PM
kupras
Oct 17, 2003 11:30 PM
