how do you remove ej2 sideskirts???
most hood white kid
probably some easy question, BUT after the driver side one fell off, I was gonna do the ek sideskirt swap...but I can not get the passenger side one off for the life of me. all of the screws in the bottom of them have been removed, and they still will not come off...anyone got anything?
Re: how do you remove ej2 sideskirts??? (egcoupe94)
make sure al the screws at the bottom are out, then there is one maybe 2 in the front wheel well. Then just push the entire skirt towards the front wheel and its off
most hood white kid
Re: how do you remove ej2 sideskirts??? (-Gambit-)
all of them are out, even the ones in the front. I had to take the fenders off so I know I got those out...but when you say push the skirt, I tried that, I jsut may not have been pushing hard enough. ehh...its took wet outside to do it....damn rain!
most hood white kid
thanks for the help bro...I just felt that I was gonna push it too hard and break something...
I thought you pushed it towards the rear of the car? Either way, once the screws are out, slide the skirt and then it will pull off, leaving the clips in the body of the car.
most hood white kid
Re: (h22crxoner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxoner »</TD></TR><TR><TD CLASS="quote">a pry bar and a 5lb sledge
now follow these directions...get someone to hit you over the head with that 5 lb. sledge...
most hood white kid
Re: (civicseth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicseth »</TD></TR><TR><TD CLASS="quote">Confirmed: slide forward.</TD></TR></TABLE>
thanks buddy...
thanks buddy...
Re: (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 »</TD></TR><TR><TD CLASS="quote">
thanks buddy...</TD></TR></TABLE>
make sure you got all those little plasic clips out as well. It won't slide anywhere with them in. Once you get them all out, you ought to be able to pull the skirt down a bit and slide it.....
most hood white kid
Re: (qat727)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qat727 »</TD></TR><TR><TD CLASS="quote">
make sure you got all those little plasic clips out as well. It won't slide anywhere with them in. Once you get them all out, you ought to be able to pull the skirt down a bit and slide it.....</TD></TR></TABLE>
you cant get those clips out with the sideskirt still on there right? and you are talkiking about the white clips...
Re: (egcoupe94)
nah.... not the white ones..... underneath the sideskirt, there are black plastic screw thingies.... you have to use a phillips and screw the center part out, then you just pull the expanding part out and you're good to go.
most hood white kid
Re: (qat727)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qat727 »</TD></TR><TR><TD CLASS="quote">nah.... not the white ones..... underneath the sideskirt, there are black plastic screw thingies.... you have to use a phillips and screw the center part out, then you just pull the expanding part out and you're good to go.</TD></TR></TABLE>
yeah, I know what you're talkin bout matt. I got all of those, thats why I was puzzled cuz it wouldnt come off....
Jonnyr4c
19
06-27-2006 06:40 PM
payneth
12-19-2003 09:23 PM
