Some Spring Questions: 92-96 Lude on AGX's
Old Jan 17, 2006 | 12:11 PM
DarkBB4's Avatar
Default Some Spring Questions: 92-96 Lude on AGX's
hey when i first bought my car last year, it needed new suspension becausue it was riding on lowering springs w/ stock shocks.. So i Put on New KYB agx shocks with teh existing lowering springs, but now the springs are shot.. they are all rusty , and just garbage! im not sure what brand they are, but Im .looking for a new set of springs that is low... preferablly 1 finger gap or less on all 4 corners (before i had 1 finger in the front, 3 in the back)... what would you reccomend? should i get a front camber kit too?
Old Jan 17, 2006 | 01:18 PM
pentaq's Avatar
Default Re: Some Spring Questions: 92-96 Lude on AGX's (DarkBB4)
you can have 1.5" drop with agx
Old Jan 17, 2006 | 04:03 PM
kb798's Avatar
I think Neuspeed Race springs lower the car the most, but if you really want to slam the car it's best to go with coilovers IMO. I'd say go with GC with the AGX, and you can change the height of your ride as you please.
If you're worried about uneven tire wear, then change the toe setting rather than getting a camber kit. As long as the toe is set to 0, it won't accelerate the uneven wear of the tire.
Old Jan 17, 2006 | 08:08 PM
97lude's Avatar
Default Re: (kb798)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kb798 &raquo;</TD></TR><TR><TD CLASS="quote"> I'd say go with GC with the AGX, and you can change the height of your ride as you please. </TD></TR></TABLE>
Old Jan 17, 2006 | 08:20 PM
InvaderTrax's Avatar
Eibach Pro Kit
H&R Sport springs
Neuspeed sport springs
Old Jan 20, 2006 | 08:35 AM
krnfly2damoon's Avatar
Default Re: (InvaderTrax)
naw naw...
Eibach PRokit lowers about 1.2 inch...
if you want to LOWER your car, get Eibach Sportline which lowers about 2inch.
or if you have the $$$ get GRound Control because you can ADJUST the height
I find the EIbach brands the best because they are not TOO hard and lowers good
and GC use Eibach springs i believe.
BergmanEM2
Suspension & Brakes
13
Mar 27, 2015 10:35 PM
db8int3gra
Suspension & Brakes
13
Jan 19, 2009 12:25 PM
red95integ
Aug 13, 2004 12:26 PM
devilpuppy
Jul 1, 2004 05:48 AM
jordan88
22
Mar 10, 2003 01:47 PM
