What bearings?
Old Jan 17, 2006 | 09:35 AM
stephen_civic98's Avatar
Default What bearings?
I have to replace my input shaft bearing in my 95 civic DX tranny. What other bearings should I replace why i am in there.
Like what are the names of them, so when i go to honda to order the bearings, i get the right ones. Thanks for any and all help!
-Stephen
Old Jan 17, 2006 | 09:48 AM
fms1day's Avatar
Default Re: What bearings? (stephen_civic98)
I don't have names but I do recommend just looking for another tranny rather than buying bearings and then taking apart the tranny to replace the bearing. I heard that it's very difficult to replace and fragile. Unless you don't plan on doing it yourself, and plan on going to a shop, they'll charge you more than what you can spend to get a used tranny in good condition. Just my $0.2
Old Jan 17, 2006 | 09:56 AM
Rionmann's Avatar
Default Re: What bearings? (fms1day)
Well while you in there, you could also replace the throw-out bearing, clutch (if neccesary), flywheel (if neccesary) , but for other bearing I don't know...
Old Jan 17, 2006 | 11:23 AM
I have a friend that works at a trannyshop thats going to help me do it for free.. plus i just spent 150$ on this tranny, so to me, its cheaper to buy bearings then to replace the tranny... again... and throwout is a brand new exeedy throwout and clutch
Old Jan 17, 2006 | 11:50 AM
snatch's Avatar
Default Re: (stephen_civic98)
There is another bearing opposite the input shaft bearing on the mainshaft, and there are other ball bearings on the countershaft not to mention several needle bearings on both shafts. If you want to spend the money, replace all you can while you're in there. Typically the input shaft bearing is the first to go bad though. Just look at the guy's computer screen when you're in there and tell him which ones you want. If you friend works at a tranny shop he should be able to tell you which other ones would be good to replace as well.
Wheelman-CZ
10
May 27, 2006 11:50 AM
ExtendedPurple
Oct 8, 2005 01:29 AM
jondancer
Apr 13, 2003 04:30 PM
LsTurbo91
Jul 16, 2002 08:00 PM
