06 rsx grind in second gear ALREADY
Old Jan 17, 2006 | 06:57 AM
Guest
Posts: n/a
Default 06 rsx grind in second gear ALREADY
any easy fix?
Old Jan 17, 2006 | 07:19 AM
initialse7en's Avatar
Default Re: 06 rsx grind in second gear ALREADY (40)
just take it to the dealer
it should be covered under warranty
Old Jan 17, 2006 | 08:26 AM
Slow EJ8's Avatar
Default Re: 06 rsx grind in second gear ALREADY (initialse7en)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by initialse7en &raquo;</TD></TR><TR><TD CLASS="quote">just take it to the dealer
it should be covered under warranty</TD></TR></TABLE>
What he said, if you just got it then make them fix it. Dont let up till they do.
Old Jan 17, 2006 | 11:16 AM
DC5AM's Avatar
just hope they don't give you the "I had the technicians road test it and we were unable to replicate the problem" b.s.
good luck getting it fixed man.
Old Jan 17, 2006 | 11:37 AM
ac_attak's Avatar
I dont know about acuras much yet, but when my mazda had the second gear grind i put in some gm syncromesh gear oil and now it shifts like brand new.
But where your car is new, take it to the dealer and bitch at them to fix it.
Old Jan 17, 2006 | 11:58 AM
ekferio's Avatar
Default Re: 06 rsx grind in second gear ALREADY (DC5AM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5AM &raquo;</TD></TR><TR><TD CLASS="quote">
good luck getting it fixed man.</TD></TR></TABLE>
that's always the case, they are either numb nuts who can't feel anything or drive like 5 mph on a test drive
Old Jan 18, 2006 | 02:49 AM
Revolution2zz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 40 &raquo;</TD></TR><TR><TD CLASS="quote">any easy fix?</TD></TR></TABLE>
how fast are you shifting it? like are you powershifting/speed shifting it already?
I know I use to get a slight "scratch" when i shifted really fast in my 05 for the first 2000 miles, then it went away afterwards. Also did it in my friends brand new 03 Si when he first got it, it also went away after some miles.
Old Jan 18, 2006 | 11:07 AM
Guest
Posts: n/a
Default Re: 06 rsx grind in second gear ALREADY (Revolution2zz)
i don't drive it hard, once in a while i gun it, but thats once in a while.....its almost always a grind unless i take it reallyyyy slow.
btw, i got like close to 7k miles on it, the grinding should have disapeared by now no?
Modified by 40 at 12:23 PM 1/18/2006
Old Jan 18, 2006 | 11:28 AM
NJslvrtypes's Avatar
The grinding is not just going to go away. If it is like the 02-04's then it is a syncro problem. Take it to the dealer and have them test drive it. If they can't replicate the problem, which they will probably say if they don't want to deal with the hassle of replacing syncros, then tell them you want to take a service rep for a ride otherwise you will file a complaint.
And there really isn't an easy fix. If it was out of warranty I would say throw in some new Redline MTF or GM Syncromesh but this should not be happening at 7k on an 06.
Old Jan 18, 2006 | 03:45 PM
rsx_vue's Avatar
Take it in to the dealship and take advantage of that warranty before it runs out. But yeha this is a common problem among rsx, although I havn't heard of any recent horror stories with the 05+ rsxs.
blackk20dc5
13
Jul 1, 2008 08:39 PM
meblahu
Dec 1, 2006 05:39 PM
mraza
13
Jul 31, 2006 08:40 AM
honkey2fly
Honda Motorcycles
62
Jul 1, 2006 09:25 PM
DFWRSXS
10
Dec 11, 2005 07:17 AM
