Almost There
Old Jan 17, 2006 | 04:46 AM
CivicScorpion69's Avatar
Default Almost There
Hey guys, I just did an engine swap in my 97. I swapped it with the same shitty engine (d16y7) just to get the feel and expireince before a "real" swap, and not to mention I got the engine for 100$ off my buddy that just did a swap. So, with everything hooked up (so I thought) it was time to turn the key, I got nothing. I took a closer look and found I didn't connect the transaxle ground. So I tried it again and got a spark where that ground was. I did get a click from the starter this time but nothing else. I took yet a closer look and found another ground to the transaxle/starter that I over looked. The only thing it does when I turn the key now is click from the relay under the dash. Nothing from the starter.. what are my possibilities here besides a possible shot starter?
Old Jan 17, 2006 | 06:40 AM
IHateJDM's Avatar
Default Re: Almost There (CivicScorpion69)
try swapping out batteries with a friend, or jump it. you may not have enough power to turn the starter left in your battery.
Old Jan 17, 2006 | 07:12 AM
Default Re: Almost There (IHateJDM)
I was jumping it with a booster pack. but the batt did sit for 2 years
Old Jan 17, 2006 | 07:20 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicScorpion69 &raquo;</TD></TR><TR><TD CLASS="quote">I was jumping it with a booster pack. but the batt did sit for 2 years </TD></TR></TABLE>
if it sat that long, it might be shot. see if you can borrow one from a friend to test with.
blueb16-em1
Jun 19, 2008 05:12 PM
mustninty20
Sep 27, 2007 01:29 PM
Turbo Bora
May 15, 2007 08:27 AM
IN2VTEC
Apr 16, 2004 03:00 PM
1fastdc2
Jan 6, 2004 12:20 AM
