crx suspension???
Old Jan 16, 2006 | 10:26 PM
sprayhappy359's Avatar
Default crx suspension???
well, i have figured out the running gear for the car...b18c5, ys1 trans, act clutch xtss, prolite flywheel... anyway- next is the suspension. i have the coilovers, but i want to buy rims at least 16" by 7" wide, maybe 17" by 7"... can i have the car dropped 1.5"-2.0" and not have 16"s or 17"s rub. cuz i dont want to buy new rims and not have them work. i have 15" gsr hammers on ot now, im new to the honda world, so help lol.
Old Jan 17, 2006 | 03:09 AM
downest's Avatar
Default Re: crx suspension??? (sprayhappy359)
Since you're new I'll tell you, don't get 16" or 17" wheels. Not only will they look ridiculous, but nobody on HT will help you when they rub against your fenders and stuff, they will only tell you to go back to the fat fives. Really, 15" is your best bet, especially if you are racing. I know you can drop around 2" with 15" wheels, but beyond that I don't know.
Old Jan 17, 2006 | 04:36 AM
mahatma's Avatar
Default Re: crx suspension??? (downest)
Nothing wrong with 16s.....
But just so you know I've had a CRX dropped 3"+ on 17" wheels with no rubbing. 205 tire is key, but 17" is really too big.
Old Jan 17, 2006 | 04:44 AM
tangerinebeast's Avatar
i have 17" x 7" and they rub only when you have the wheel cut all the way and hit a bump to fast it is only lowerd maybe 1.5"
Edit: for to mention that usually the only reason tires wear is not from rubbing but from your camber because of it being lowered
Old Jan 17, 2006 | 06:08 AM
CRX Toad's Avatar
Default Re: (tangerinebeast)
17's are not going to be your best choice. They will make your car ride like a hay wagon. I would leave you current 15"s on there for several reason ride, you can lower a little more, and tires are cheaper. Stay with the 15's.
Old Jan 17, 2006 | 08:25 AM
Autoworks's Avatar
Default Re: (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">17's are not going to be your best choice. They will make your car ride like a hay wagon. I would leave you current 15"s on there for several reason ride, you can lower a little more, and tires are cheaper. Stay with the 15's.</TD></TR></TABLE>
Agreed, but if you insit on bigger wheels Use...
17"- 205/40-17
16"- 215/40-16 or 205/40-16
93civcx
39
May 18, 2009 07:33 PM
JDM.Jay
Mar 13, 2007 11:04 AM
91cvcsi
29
Nov 11, 2004 11:35 PM
civboy115
17
Mar 16, 2004 02:03 PM
EJ2-Fluffy
Jun 7, 2003 04:52 PM
