Gangsta Lean Radiators
Old Jan 16, 2006 | 05:07 PM
TurboEM1's Avatar
Default Gangsta Lean Radiators
Hey I am looking for a half size radiator for my turbo crx but i dont want it to gangsta lean. I have done a lot of research and found that all the "ef half sizes" are the same ones they sell people with eg's and thats why they dont fit. I remeber coming across one company that actually made a crx specific one that fit good. Anyone know what half size wont lean and will fit right? Koyo, PWR, Fluidyne, ect? Thanks
Old Jan 16, 2006 | 05:10 PM
yz125rider21's Avatar
if I recall full race makes a full setup so there no more gangsta lean I could be wrong...but if I am that will save me money cause I was gonn get there traction bar with radiator with my income tax....
Old Jan 16, 2006 | 05:13 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (yz125rider21)
you may check out a dodge neon half radiator.. i have *heard* this fit perfectly into the notches that an ef already has, and is the correct hight so no gangsta lean.. i think its the '99 non ac manual but you should double check before you buy one..
may be a lot cheaper to go that route.. if your into cheap.. heh
edit: 95-99 non-ac manual or auto neon has them.. youll need the filler neck as seen in the picture in this thread:
https://honda-tech.com/zerothread?id=295105
Old Jan 16, 2006 | 05:20 PM
kulangot's Avatar
Default Re: (sanimalp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sanimalp &raquo;</TD></TR><TR><TD CLASS="quote">you may check out a dodge neon half radiator.. i have *heard* this fit perfectly into the notches that an ef already has, and is the correct hight so no gangsta lean.. i think its the '99 non ac manual but you should double check before you buy one..
https://honda-tech.com/zerothread?id=295105</TD></TR></TABLE>
good info....but i have a lean, i dont think its gangsta thou..
Old Jan 16, 2006 | 05:23 PM
Pee Wee's Avatar
Default Re: (kulangot)
y<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yz125rider21 &raquo;</TD></TR><TR><TD CLASS="quote">if I recall full race makes a full setup so there no more gangsta lean I could be wrong...but if I am that will save me money cause I was gonn get there traction bar with radiator with my income tax....</TD></TR></TABLE>
yup, ive got the radiator and traction bar setup. no lean at all.
Old Jan 16, 2006 | 08:09 PM
B16CRXT's Avatar
Default Re: (EF8opey)
What I did to get my EG half radiator to fit, was cut that support bracket below it in half so it could sit lower and straight. I then welded a bracket that hangs about an inch lower than the part that I cut out, for the radiator to sit on. Hope that made some sense. If you have a turbo crx, you should be used to fabricating and cutting stuff
Old Jan 17, 2006 | 02:13 AM
Sgt_Ox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8opey &raquo;</TD></TR><TR><TD CLASS="quote">y
yup, ive got the radiator and traction bar setup. no lean at all.</TD></TR></TABLE>
Here you go even more proof. This is with a SPAL 11" High Performance rad fan mounted.
SeraphimKidd
Sep 28, 2009 04:03 PM
bigcivman09
Feb 22, 2009 06:22 AM
95_red_dc
Feb 6, 2009 10:31 AM
negum
Sep 7, 2008 03:41 PM
ham
Dec 27, 2005 11:50 AM
