D16y7 high pitch sound at around 4500 5k RPMS ?
Old Jan 16, 2006 | 04:09 PM
Ser1N's Avatar
Default D16y7 high pitch sound at around 4500 5k RPMS ?
Hey,
Strange thing, i got this car used with 85k miles on it. When i get up to around 4500 - 5k RPMS and up i get a very high pitch sound. Im not sure where is it coming from other then i know its coming from the engine bay. Has anyone else heard of anything like this?
Thanks
Old Jan 16, 2006 | 04:58 PM
Laserjock's Avatar
Default Re: D16y7 high pitch sound at around 4500 5k RPMS ? (Ser1N)
that happened to me when I installed a ram air intake. it kinda sounded like a turbo.
i liked it so much i pieced together a HMT kit!
Old Jan 16, 2006 | 04:59 PM
Ser1N's Avatar
I donno haha, im totaly stock =x so i donno.
Old Jan 16, 2006 | 06:01 PM
mluckxxx's Avatar
same thing happens to me. do a valve adjustment. my cars at 87,xxx
Old Jan 17, 2006 | 08:38 AM
Ser1N's Avatar
Default Re: D16y7 high pitch sound at around 4500 5k RPMS ? (mluckxxx)
hMM valve adjustment, never even thought that could be it, wonderfull i will do that this weekend. Could the valve also cause the bog down i get from 1k rpms to the 3k rpms.
When i take off the car seems like it has NO power at all untill around 3k THEN i can feel the car pull some =P.?
Old Jan 17, 2006 | 09:08 AM
00ekcoupe's Avatar
ITS VTAKK!!
Old Jan 17, 2006 | 09:29 AM
Ser1N's Avatar
Default Re: D16y7 high pitch sound at around 4500 5k RPMS ? (00ekcoupe)
if i had vtak!
Old Jan 17, 2006 | 10:13 AM
ShadowCoupe94's Avatar
same thing happens to me. its air flow
Old Jan 17, 2006 | 11:05 AM
young noob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00ekcoupe &raquo;</TD></TR><TR><TD CLASS="quote">ITS VTAKK!! </TD></TR></TABLE>
d16y7 non-vtec
Old Jan 17, 2006 | 11:38 AM
mluckxxx's Avatar
Default Re: D16y7 high pitch sound at around 4500 5k RPMS ? (young noob)
ive got the d16y7 too, sucks.
im gonna be swapping a d16z6 head onto it in a matter of weeks though :D
Old Jan 17, 2006 | 12:11 PM
eknorcal's Avatar
i dont know what u mean by high pitch sound but it may be the tranny.
Old Jan 17, 2006 | 01:26 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: D16y7 high pitch sound at around 4500 5k RPMS ? (eknorcal)
Mine does the same thing. Started after I got my car back from the BODY shop (those *******) and it was 10k miles AFTER i put the SRI in. i'll go do a valve job and see if that helps.
Old Jan 17, 2006 | 02:06 PM
y7turbo's Avatar
Default Re: D16y7 high pitch sound at around 4500 5k RPMS ? (Redline96LX)
belts maybe? maybe a bearing in a pulley is going bad and it starts to make noise after that rpm..
Old Jan 17, 2006 | 02:15 PM
pumatec8's Avatar
i asked about this a while back and got an answer saying that it was the throttle body plate...apparently if it is a little bit off it will cause the air coming into the intake manifold to whistle...it hasn't posed a problem for me though...
mine may be a little different...it whistled from ~2k-3.5k...but same sorta thing
Old Jan 17, 2006 | 02:16 PM
Ser1N's Avatar
Default Re: D16y7 high pitch sound at around 4500 5k RPMS ? (pumatec8)
Ill take a look into the intake deal also, and how much is the pully / labor to install one?
Old Jan 17, 2006 | 02:42 PM
97spooncivic's Avatar
its stec, scam-tec. i would say that its a whistle sound from the tb plate or maybe, just maybe, you need valve adjustment
Old Jan 17, 2006 | 05:00 PM
mluckxxx's Avatar
Default Re: D16y7 high pitch sound at around 4500 5k RPMS ? (97spooncivic)
i have this same problem and i was told its not the valves, im throwing a CEL 67 (cat,) so my car is a little sick right now.
DoubleM
Jul 19, 2017 02:58 PM
Shaguar47
Aug 27, 2012 04:55 AM
90civichbsi
Oct 25, 2009 06:53 PM
briq4
Honda Civic (2001 - 2005)
Sep 20, 2009 04:42 AM
DeBo
13
Mar 12, 2003 07:52 PM
