Porting with Carbide Deburr on Aluminum?
Old Jan 16, 2006 | 02:30 PM
FastCougar's Avatar
Default Porting with Carbide Debur on Aluminum?
I just realized that I ordered the wrong debur kit to port my aluminum heads. Are there any down sides to using carbide debur porting tools on aluminum heads? By "wrong" kit, I mean that I just noticed that they also offer a "non-ferrous" debur kit ... would I be wasting money sending this kit back and getting it, or is it absolutely necessary?
Old Jan 16, 2006 | 04:05 PM
dfoxengr's Avatar
Default Re: Porting with Carbide Debur on Aluminum? (FastCougar)
show me a link to what you got.
Old Jan 16, 2006 | 04:26 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Re: Porting with Carbide Debur on Aluminum? (dfoxengr)
Ive always used aluminum specific or non ferrous burrs. I had a burr that a friend gave me that looked a little different from the ones i had. The the edges(blades) of the burr were alot closer together than my aluminum ones. Well i tried it and it worked ok...except for the fact that it got clogged up after like 2 minutes . I belive this bit was meant for iron and steel and such. I say send them back and get some for aluminum heads.
Old Jan 16, 2006 | 05:44 PM
91TSiGuy's Avatar
Default Re: Porting with Carbide Debur on Aluminum? (sCeRaXn)
The double cut carbide burr bits you got will still work on aluminum, but you will definitely want to run a lot lower air pressure with these so they don't load up as easy. I would say run about 30-40psi line pressure. The non-ferrous single cut ones will obviously work better and have less of a chance clogging, but you can make do with either one.
Old Jan 16, 2006 | 06:17 PM
rpm11's Avatar
You should use something for a lubricant and go slow.
Old Jan 16, 2006 | 06:46 PM
TGrant's Avatar
The downside to using those bits is that they will clog up. Do not use a lubricant, it wont help.
Old Jan 16, 2006 | 07:13 PM
tony1's Avatar
Default Re: (TGrant)
Lubricant WILL help, it'll make all the difference in the world. Spray some wd40 on it and it won't clog...
Old Jan 16, 2006 | 07:31 PM
rpm11's Avatar
I use a special lube I get from Roger Helgesen,
but a lot of the time I spray enough WD40 or LPS to pool in the bowl, then I can dip the burr
in the pool every few seconds.
Old Jan 16, 2006 | 10:36 PM
FastCougar's Avatar
Default Re: (rpm11)
Thanks for the input guys. I will stick with these for now since it's only light port matching and very little PnP. I tested them out on a spare set of trashed heads (fried motor blew the rings into the heads) ... worked very well thanks! These where the summit $45 4 bit set ... they want $59.95 for a 3 bit non-ferruous set ... I will deal with these and pocket the savings
Old Jan 17, 2006 | 02:15 AM
k24em2's Avatar
Default Re: (FastCougar)
Bees wax on the cutter.
Old Jan 17, 2006 | 06:21 AM
Bailhatch's Avatar
Default Re: (k24em2)
check out american-carbide.com. good prices, quality burrs and good shipping. they even have aluminum cutting ones
Old Jan 18, 2006 | 06:48 PM
Justin Jones's Avatar
when you do get non-double cut burrs you will notice the difference and wish you got them in the first place. at least that's what happened to me aluminum will f*ck **** up on double cuts... good luck and try getting tool saver goop for the burrs.
Old Jan 19, 2006 | 06:48 PM
silentdaredevil2's Avatar
the only difference between what u got and a non ferrous one is the design of the cutter because aluminum is so soft compared to a carbon steel or casted steel. it will clogg the cutter very quickly. its just like using an endmill ment for steel on aluminum, it will clog and u will get no where. it has to do with the flute design
Roboy88
Honda Civic (2006 - 2015)
Sep 22, 2008 02:36 PM
B33R
Honda S2000
Feb 17, 2007 11:09 AM
Toretto
May 6, 2002 09:04 AM
voltronR34
Apr 5, 2002 10:17 AM
